A4988 motor driver
I'm just using an arduino uno and a single A4988 driver to power my stepper motor, the pins (ms1,ms2 and ms3) are disconnected so the motor is running in full step mode, but I would like to try different resolution like (half,quarter,eight etc) but I cannot find information on how to connect those pins, someone knows how to do that?, this is my board:
You image did not take, post it as an attachment will do the trick.
Where did you purchase the board?
Thanks.. Tom.... :)
You can't break it. Just hook the pins up to your logic supply voltage (3.3 or 5 volts.) I use breadboard jumper wires.
Some combinations of the 3 pins are not effective, but it doesn't break the chip if you pick a "wrong" one.
https://www.pololu.com/product/1182 has the details.
maad: but I cannot find information on how to connect those pins
Did you think to try googling "A4988 datasheet" ? That's how to find out about a chip.
MarkT: Did you think to try googling "A4988 datasheet" ? That's how to find out about a chip.
Don't tell him about Google! You'll ruin the secret and none of us will appear half as clever anymore.
