a6 gsm module trouble shooting
this code is to send message to specific number:
char phone_no[]="9488072237";
delay(300);
Serial.println("AT+CMGF=1");
delay(2000);
Serial.print("AT+CMGS="");
Serial.print(phone_no);
Serial.write(0x22);
Serial.write(0x0D); // hex equivalent of Carraige return
Serial.write(0x0A); // hex equivalent of newline
delay(2000);
Serial.print("data!!!!");
Serial.println (char(26));//the ASCII code of the ctrl+z is 26
this is normal program to write AT commands manually in serial monitor :
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
these 2 are working but i need as code to send a msg automatically in a daily basis...
i need a code or configuration or instruction.
Guys i need help,
