I'm really in need of help with this problem and as most commonly advised, I have researched and researched and researched for days and I can't figure out what's wrong...
With that being said, I'm working on a project that uses an ESP-32S (pinout) and an A6 GSM module. (pinout) I'm attempting to get them connected to have the A6 send data to ThingSpeak... My problem is that I can't get it to work... I have the exact same configuration between the two using an ESP8266 and it connects and works but with the ESP32S it just doesn't seem to work...
Below is the code I have used to connect the 32 to the A6 and everything says success and pass but it won't change any ThingSpeak values using any methods...
#define TINY_GSM_MODEM_A6
#include "TinyGsmClient.h"
#include "ThingSpeak.h"
#define SerialMon Serial
HardwareSerial SerialAT(1);
bool modemConeted;
// Your GPRS credentials
// Leave empty, if missing user or pass
const char apn[] = "wireless.twilio.com";
const char user[] = "";
const char pass[] = "";
bool dataSent = false;
TinyGsm modem(SerialAT);
TinyGsmClient client(modem);
void setup(){
SerialMon.begin(9600);
gsmModSetup();
void gsmModSetup() {
// Set GSM module baud rate
SerialAT.begin(9600, SERIAL_8N1, 27, 26, false); //27 and 26 are the pins on the ESP32S connected to the U_Rxd/U_Txd pins of A6
delay(3000);
SerialMon.println("Initializing modem...");
modem.init();
delay(3000);
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem: ");
SerialMon.println(modemInfo);
SerialMon.print("Waiting for network...");
if (!modem.waitForNetwork()) {
SerialMon.println(" fail");
delay(10000);
return;
SerialMon.println(" OK");
SerialMon.print("Connecting to ");
SerialMon.print(apn);
if (!modem.gprsConnect(apn, user, pass)) {
delay(5000);
return;
void loop(){
I'm using a Twilo Sim card that's loaded with data (as said above it works with esp8266 so not the SIM and not the board) The only part of this code that doesn't pass is the part that says GPRS connect. it never says pass or fail. It just sits for like five minutes then continues.
After this, I try and post to ThingSpeak and it gives ThingSpeak ERROR-307 which means failed to connect to ThingSpeak...
I have tried 2 different ways
The what I find the easy and normal way
ThingSpeak.setField(1, temp);
ThingSpeak.setField(2, h);
ThingSpeak.setField(3, p);
ThingSpeak.setField(4, pt);
ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
and the more complicated way of connecting to the server then sends a GET command with all the values put together with strings.
if (client.connect(thingSpeakAddress, 80))
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + WriteAPIKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(thingSpeakData.length());
client.print("\n\n");
client.print(thingSpeakData);
client.stop();
Yet neither work and I don't know what to do... My A6 is connected to the 32 using GPIO26 & 27 they're connected to the A6 U_Rxd/U_Txd pins. All boards share common ground as they should.
Any more guides to read or code to change or libraries to try would be extremely helpful as my days of digging has yielded nothing but frustration as one attempt after another fails. the readers of this really are my last hope in solving this problem that's hindering my farther progression.
(Any questions about anything on my end, please ask. -Thank you)
