A9g HTTP POST and HTTP GET AT Commands
Hi guys, I am facing a issue when trying to make HTTP Post and HTTP Get Commands using A9G Module with arduino Meg. I Want to post data to firebase realtime database and also read data from the same database using A9g GPRS internet connectivity but my code cant seem to work and i dont know whats the problem, and i am always getting CME error 58. could you please help me. this is the code:
#include <SoftwareSerial.h>
SoftwareSerial A9GSerial(10, 11); // RX, TX
    A9GSerial.begin(115200);
    delay(5000);
    // information to be posted
    float temperature = 25.5;
    float humidity = 60.0;}
void initializeA9G() {
    sendATCommand("AT");
    delay(5000);
    sendATCommand("AT+CFUN=1");  // Enable full functionality (disable airplane mode)
    delay(5000);
bool checkNetworkRegistration() {
    sendATCommand("AT+CREG?");
    // Check the response for network registration status
    if (A9GSerial.find("+CREG: 1,1") || A9GSerial.find("+CREG: 0,5")) {
        return true;
        return false;
bool attachGPRS() {
    sendATCommand("AT+CGATT=1");
    delay(5000);
    // Check if GPRS is attached
    if (A9GSerial.find("+CGATT: 1")) {
        return true;
        return false;
bool connectToInternet() {
    sendATCommand("AT+CGDCONT=1,\"IP\",\"m-internet\"");
    delay(2000);
    sendATCommand("AT+CGACT=1,1");
    delay(5000);
    // Check if PDP activation is successful
    if (A9GSerial.find("OK")) {
        return true;
        return false;
bool sendDataToFirebase(float temperature, float humidity) {
    String firebaseURL = "https://base-de-dados-mmaip-default-rtdb.firebaseio.com/sensorData";
    // Create JSON data
    String jsonData = "{\"temperature\":" + String(temperature, 2) + ", \"humidity\":" + String(humidity, 2) + "}";
    sendATCommand("AT+HTTPINIT");
    delay(2000);
    sendATCommand("AT+HTTPPARA=\"CID\",1");
    sendATCommand("AT+HTTPPARA=\"URL\",\"" + firebaseURL + "\"");
    sendATCommand("AT+HTTPPARA=\"CONTENT\",\"application/json\"");
    sendATCommand("AT+HTTPDATA=" + String(jsonData.length()) + ",10000");
    sendATCommand(jsonData);
    sendATCommand("AT+HTTPACTION=1");
    delay(15000);
    // Check if HTTP POST was successful
    if (A9GSerial.find("HTTPACTION: 1,200")) {
        return true;
        return false;
void sendATCommand(String command) {
    A9GSerial.println(command);
    Serial.print("Command: ");
    while (A9GSerial.available()) {
        char c = A9GSerial.read();
        Serial.print(c);
Cellphone here.... Try Google on "CME error 58"!
I did it... it is a network error. I checked everything related to gprs activation on my code and i always get positive feedback
Is there no further expalantion what's wrong/missing etc?
We are at the edge of my experience by now. The last suggestion is to look for deeper/ more detailed information.
this is what i get from the serial monitor:
11:38:44.017 -> Command: AT
11:38:44.017 -> AT
11:38:44.017 ->
11:38:44.017 -> OK
11:38:44.017 ->
11:38:49.444 -> Command: AT+CFUN=1
11:38:49.444 -> AT+CFUN=1
11:38:49.444 ->
11:38:49.444 -> OK
11:38:55.003 ->
11:39:00.552 -> Command: AT+CGDCONT=1,"IP","m-internet"
11:39:00.552 -> AT+CGDCONT=1,"IP","m-internet"
11:39:00.552 -> OK
1:39:06.118 -> Command: AT+CGACT=1,1
11:39:06.118 -> AT+CGATT=1,1
11:39:06.118 ->
11:39:06.118 -> +CME ERROR: 58
11:39:06.118 ->
11:39:11.629 -> Command: AT+HTTPINIT
11:39:11.629 -> AT+HTTPINIT
11:38:49.444 ->
11:39:11.671 ->
11:39:11.671 -> CME ERROR 58
11:39:11.671 ->
11:39:17.198 -> Command: AT+HTTPPARA="CID",1
11:39:17.198 -> AT+HTTPPARA="CID",1
11:39:17.198 ->
11:39:17.198 -> +CME ERROR: 58
and just getting CME ERROR 58
Please... You dig deeper in the system documentation. I'm at the end of the road.
