I have a 5V Arduino and 3V motors. They are powered by separate 4 AA battery packs. The battery packs are quite bulky and heavy. Would LiPo help?
Separate battery packs are used to prevent interference and because the motor drains much faster than the Arduino. These are the motors: http://www.pololu.com/catalog/product/114
A 4 AA battery pack would be equivalent to 8 LiPos. I guess you could put 4 LiPos in the Robot while the other are charging. I guess 1 or 2 2-cell LiPos would could power the Arduino for a fairly long time, but the motor would need 4 single cell batteries.
This sounds like a modest weight savings.
Is this right? Is it worth converting to a 3.3 V Arduino as 3.3V devices like the motors require single cell batteries?
Not quite, Li-Po is 7.4 V pack, you need 5 AA for 1 Li-Po.
I would not convert to 3.3V just because your motors 3V. Use 3.7V Li-Po for motors, and 7.4V for arduino. In long run you would save a lot money not buying AA. Or you can run your robot from single 7.4V battery (Li-Po). and set a limits in software PWM to 40 % max duty cycle.
3V / 7.4V = 0.4054 ; analogWrite ( from 0 to 0.4054 x 255 = 103 )
How you drive a motors?
Personally, all of my future projects are going to be based around 3.3v. I really feel it's the more popular voltage range for embedded electronics. With ARM chips on the rise and working with 3.3v instead of 5v, I see no reason to continue to work in 5v.
I'm sure there are perks to 5v that I don't know since I'm still a newbie but it seems like the majority of components I'd want to use either only work in the 3.3v range, or work in both 3.3v or 5v.
As for your statement:
I think you are referring to the capacity ratings here, and in that case no. A 4 AA pack is most likely wired in series which means your capacity is not being increased. 4 AAs of 2000 mAh capacity each wired in series still gives you ~2000 mAh over all capacity, however wiring in series combines voltage so 4 AA in series is ~6v. So in this case 4 AA would be equivalent to 2 - 1000 mAh Lipos (wired in parallel not series) as for capacity. However if you only need 3v on the motors sparkfun has a 2000 mAh 3.7v Lipo that might be a better choice for you if you go that route: Lithium Ion Battery - 2Ah - PRT-13855 - SparkFun Electronics you just need to make sure the discharge rate is sufficient on the 3.7v Lipo. It has a 2C discharge rate where as the 7.4v one you linked has a 25C discharge rate. If you convert to 3.3v arduino you can use another one of the 3.7v lipos for your arduino if you still want to keep the power supplies separate.
I found a nice explination of the discharge rates, as long as I'm understanding it correctly. 1C means the battery can discharge it's entire capacity in an hour, so a 1000 mAh battery that could discharge at 1C could provide 1000 mA for one hour. A 1000 mAh battery with a 2C discharge rate could provide 2000 mA for 30 minutes (or 1000 mA for an hour still). Going the other way, if a battery with 1000 mAh capacity had only say a .25C discharge rate, it would only be capable of supplying 250 mA for 4 hours. So the 2000 mAh 3.7v Lipos can supply up to 4000 mA for 30 minutes (or 2000 mA for 1 hour, etc). The 7.4v lipos with a 25C discharge rate would be capable of supplying 25,000 mA for approximately 2 1/2 minutes. So if your motors have more than 4000 mA current draw then the 3.7v Lipo would not be sufficient to power it.
It is expensive. 1 charger ($33), 1 motor battery ($17), 1 spare motor battery ($17), 1 arduino batter ($7) and 1 spare arduino battery ($7) costs around $81+s/h. Assuming I can find a good charger, I hope it cuts down on the weight and works smoothly. My tracked robot was kind of crappy, so just replaced some cardboard sides with HPDE. The AA battery packs did not fit well in the frame, so hoping these would fit better and be easier to change.
