AAC Keys does not convert my serial code in a keyboard command?
I have troubles getting my AAC Keys to work.
When I send some serial characters to my mac, the code will just be written on a text editor for example.
But AAC Keys is not converting it in a keyboard command like it should.
I looked through the help docs but I might understand something wrong...
That's my code to just send a return command:
Serial.print("<esc>,return.");
Do I have to convert my characters somehow?
Greets
Max
You need an 'escape character' (ASCII 27), not the text "".
Serial.print(27, BYTE);
Serial.print(",return.");
Thank you very much!
Thought it would be something like that..
how I can use combine : ctrl, alt and escape?
Gregory
Did you try ",combine,ctrl,alt,escape."?
This third party document covers the GIDEI protocol: http://trace.wisc.edu/docs/gidei/gidei_sh.htm
Hello
How i can use keys combine:
alt + ctrl + delete
Gregory
ok, thx !!!!!
I try :
combine
used to type one to five keys "simultaneously".
, combine , ctrl , alt , del .
Serial.write(27);
Serial.print(",combine,ctrl,alt,del.");
but it do not work :frowning:
