About arduino pro mini power supply and serial monitor
I want to run my arduino pro mini on an external power supply from (Vin(RAW)) or 5V pin.
Furthermore, I want to connect it to a PC at the same time and monitor the output serially.
The 5V supply will be provided from two places, is there any way to avoid this?
For example, is there a good way to cut off the supply to the arduino pro mini from the PC side?
I think it is ok for arduino UNO as it will be cut off by a comparator. 、、、、
Translated with DeepL
Use an Arduino Micro or Nano instead.
Just don't connect the Vcc from the FTDI
Removed VCC 5V from FTDI to arduino pro mini and it worked successfully. Thank you very much.
Have a nice day!
