Your button should be in an array ordered by index 0 to 6 and you should keep also the number of times a given button has been pressed (either a side array or you create a dedicated class/subclass)
When button at index n is pressed you increase its press count and use both information to calculate the new value of count (n plus 7 times the number of presses of button n)
might consider this approach where a sub-function (chkButtons()) returns which button was pressed instead of having to check each button if it was pressed
// check multiple buttons and toggle LEDs
enum { Off = HIGH, On = LOW };
byte pinsLed [] = { 10, 11, 12 };
byte pinsBut [] = { A1, A2, A3 };
#define N_BUT sizeof(pinsBut)
byte butState [N_BUT];
int
chkButtons ()
for (unsigned n = 0; n < sizeof(pinsBut); n++) {
byte but = digitalRead (pinsBut [n]);
if (butState [n] != but) {
butState [n] = but;
delay (10); // debounce
if (On == but)
return n;
return -1;
void
loop ()
switch (chkButtons ()) {
case 2:
digitalWrite (pinsLed [2], ! digitalRead (pinsLed [2]));
case 1:
digitalWrite (pinsLed [1], ! digitalRead (pinsLed [1]));
case 0:
digitalWrite (pinsLed [0], ! digitalRead (pinsLed [0]));
void
setup ()
Serial.begin (9600);
pinMode (pinsBut [n], INPUT_PULLUP);
butState [n] = digitalRead (pinsBut [n]);
for (unsigned n = 0; n < sizeof(pinsLed); n++) {
digitalWrite (pinsLed [n], Off);
pinMode (pinsLed [n], OUTPUT);
