About Example 3 - A more complete system of Robin2's tutorial need help please
The Example 3 received message with start marker and end marker.
The Robin2's NRF24L01 SimpleTx as below, how to add a start marker '<' and end marker '>' into the message be sent?
I simply added into the line 52 got error.
Thanks
Adam
// Example 3 - Receive with start- and end-markers
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
    Serial.println("<Arduino is ready>");
    recvWithStartEndMarkers();
    showNewData();
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void showNewData() {
    if (newData == true) {
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        newData = false;
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
    Serial.println("SimpleTx Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.setRetries(3,5); // delay, count
    radio.openWritingPipe(slaveAddress);
    currentMillis = millis();
    if (currentMillis - prevMillis >= txIntervalMillis) {
        send();
        prevMillis = millis();
void send() {
    bool rslt;
    rslt = radio.write( &<dataToSend>, sizeof(dataToSend) );
        // Always use sizeof() as it gives the size as the number of bytes.
        // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print("Data Sent ");
    Serial.print(dataToSend);
    if (rslt) {
        Serial.println("  Acknowledge received");
        updateMessage();
    else {
        Serial.println("  Tx failed");
void updateMessage() {
        // so you can see that new data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
    dataToSend[8] = txNum;
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_mar12a\sketch_mar12a.ino: In function 'void send()':
sketch_mar12a:52:26: error: unable to find character literal operator 'operator""dataToSend' with 'char' argument
     rslt = radio.write( &'<'dataToSend'>', sizeof(dataToSend) );
Multiple libraries were found for "nRF24L01.h"
 Used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\RF24-master
 Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Mirf
exit status 1
option enabled in File -> Preferences.
You have to try to imagine that not everyone understands what that refers to.
You appear to be attempting to mix two different tutorials for unknown reasons.
The rf24 packet requires no start nor end markers.
Why are you trying to receive rf24 data with a serial port? To receive data send by the SimpleTx example, use the SimpleRx example and do not change the SimpleTx example.
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
    Serial.println("SimpleRx Starting");
    radio.begin();
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.startListening();
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        newData = true;
void showData() {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        newData = false;
If the SimpleRX and SimpleTX programs do not work it is because there is something wrong with your setup. That code has been tested hundreds of times and is known to work. Read and follow the simple rf24 tutorial carefully and you will have a better chance at getting them to work.
Great!
Thank you.
