About generalizing digitalRead, digitalWrite and pinMode to extender IO
I am trying to run LCD and some inputs over I2C port extenders. I was a bit disappointed to find out that was not as easy as 1-2-3. So I was looking for solutions, so that I can run liquidcrystal library without any modification, unlike what fm did or adafruit. Here is what I came up with, which should make the Arduino software a lot more powerful:
The functions digitalRead, digitalWrite and pinMode are defined in wiring_digital.c and they never check if the pin number goes beyond maximum. If I insert an if statement in all these functions to call another function in case the pin number is greater than a certain value, say 127, so the correct routine can be called to these extended pins without the liquidcrystal library or other libraries written to call these functions even know what goes on. This will easily extend liquidcrystal, keypad, all my pin_interfaces library classes. If we extend enough, we also cover PWM pins as analogWrite, analogRead with much higher accuracy with external chips. We can also couple DAC to analogWrite, all without any programs knowing that they are running on pins external to the ATMEGA chip. This is a great extension to what arduino is.
What do you think? Should Arduino team make some changes so these alternative pin access functions can be defined in the main arduino code?
wiring_digital.c
void alt_digitalWrite(uint8_t pin, uint8_t val);
void digitalWrite(uint8_t pin, uint8_t val)
  if (pin>127) alt_digitalWrite(pin,val);
  else {//do original digitalWrite}
main .ino
//digital write on external pins
interesting idea:
The alt_digitalWrite() must exist otherwise it will not compile. A better implementation might mimic the way attachInterrupt() works. - The framework has a function pointer which is default NULL. - The user can do attachDigitalWrite(altDigitalWrite); and detachDigitalWrite();
  if (pin > 127 && alt_digitalWrite != NULL )
    return;
Thanks Rob. I will do the attach detach. It is better.
An interesting variation could be
  if (alt_digitalWrite != NULL )
    if (alt_digitalWrite(pin,val) ) return;
Besides doing the extended IO alt_digitalWrite() intercepts the "normal" IO and do something. e.g. when you set pin 13 it can automatically set pin 95, or send something to an LCD , or send something over I2C.
the bool return value [true/false] decides if the original code is to be called after alt_digitalWrite().
That's really smart! I would define the digitalWrite or read as returning integer and only 0 and 1 are mapped to high and low and then maybe -1 maps to "please run original digitalWrite or read".
Arduino team should know about this!
boolean was invented for true and false ...
the signature should be bool alt_digitalWrite(uint8_t pin, uint8_t val);
an example of a serial dumper
  Serial.println(pin, DEC);
  if (pin > 20) return false;
  return true;
Yes but that will help digitalRead’s alternative function since it is expected to return true or false. I am going to implement this in Arduino IDE 1.0.5 R2 with some extender chips, just to see how far I can go with various libraries, code, and hardware.
@liudr
Have you seen this work?
https://github.com/neu-rah/Arduino-VirtualPins/blob/master/hardware/arduino/cores/arduino/virtual_pins.h
It sounds a lot like what you are describing.
More info here; https://groups.google.com/a/arduino.cc/forum/#!topic/developers/g3IqPZ2wB5k and https://github.com/neu-rah/Arduino-VirtualPins
The Cosa solution to your original issue (LCD adapters) is to use abstract interfaces. The LCD port access is done by an adapter object; an implementation of the class LCD::IO, https://github.com/mikaelpatel/Cosa/blob/master/cores/cosa/Cosa/LCD.hh#L184.
The best example of how this works is the CosaLCDbench sketch, https://github.com/mikaelpatel/Cosa/blob/master/examples/LCD/CosaLCDbench/CosaLCDbench.ino#L47. The LCD handling is three layers; 1) implementation of the LCD interface, 2) implementation of the LCD port adapter, 3) binding of the LCD driver to IOStream.
Please note that CosaLCDbench handles three types of LCDs and over 10 types of adapters ranging from 4-bit parallel to 3 wire Shift Register over SPI.
Cheers!
kowalski,
Thanks. The virtual pin seems interesting, almost what we are discussing. It only uses shift registers. I'm trying to use GPIO extender chips so they will have input and output and some pullup resistors. This makes them more like regular pins. Plus, I am trying to stay away from PROGMEM. That seems awkward. A digital read has to read from multiple PROGMEM arrays to determine what port and pin to read. It was probably the only way for ATMEGA8 to do it with such limited memory. I'll just do an attachInterrupt method like Rob suggested and report back how well it works. I am a bit apprehended by the use of github. It provides no help to a non-programmer professional. Impossible to understand what he did or what I should grab from it.
I just implemented some of the features we discussed. It seems pretty sweet. I can even use this generalization to do simulations! Here is a sample code:
int led = 20;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  //pinMode(led, OUTPUT);
  altDigitalWrite=&digitalWriteHaHa;
  altDigitalRead=&myDigitalRead;
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  Serial.println(digitalRead(20));
void digitalWriteHaHa(uint8_t pin, uint8_t val)
  Serial.println("haha");
int myDigitalRead(uint8_t pin)
  return HIGH;
Output:
haha
haha
1
haha
haha
1
haha
haha
1
With the attachInterrupt way, the alternative digital read write and mode can use all functions and libraries available to the main sketch, a huge convenience.
Files that need to be changed are Arduino.h to include the declarations of these alternative function pointers, wiring_digital.c with alternative functions before the original functions, and additional lines in the main sketch. I just need to test its speed on an I2C extender. Hopefully we can get 20KHz on digital pins when we run 400KHz I2C bus speed. That is enough to do an accurate photo gate setup for physics labs.
I do have some questions on how the IDE compiles files, which I will spin off a new topic. Thanks guys.
any news about this?
virtual pins uses i2c and spi devices and some experimental modules to turn and arduino into an i2c or spi server
this forms a network were mcu’s can use devices wired to buses or behind other mcu’s.
its interesting, can preserve compatibility and allows abstraction of certain libraries over the medium…
find me on my github account if you want to discuss this.
I've just finished writing a library that provides support for differing IO requirements in libraries. It requires a one-off library change, but after that one can choose if arduino pins or an IO exapnder should be used. Currently, it supports i2c (8574), shift registers and direct pins.
Please see my git hub fork of LiquidCrystal that supports i2c, shift registers and arduino pins using a simple abstraction. It's not fully finished off, but should be enough to get the idea.
I'm looking for feedback on what people think of it anyway, comments good or bad welcome!
The forked LiquidCrystal: https://github.com/davetcc/LiquidCrystal
The abstraction library: https://github.com/davetcc/BasicIoAbstraction
Some more documentation about the library: http://www.thecoderscorner.com/electronics/microcontrollers/switches-inputs/basic-io-abstraction-library-pins-or-8574/
Something of note that I missed in my last reply is that there is a significant difference between serial and direct pins, in that each read or write operation with the device is much heavier, with significant overhead.
In the library, this is one of the issues I faced when trying to use with things like LiquidCrystal and monitoring items in real life, I eventually came up with the idea of a commit operation that updates the device. This means that the process is: 1. Setup the various outputs how you want them. 2. Call runLoop() and then 3. Read back any input variables. This can all be done in one operation for the i2c 8574.
In use it does look a little bulky but it improves performance, especially in the i2c case.
