About mosfet, pwm, arduino
Can i use low voltage mosfet for arduino? I want to drive a led strip with a mosfet that runs from 1 to 1.2 volts. Tell me, is it possible to adjust the pwm ceiling from 5 to 1.2 volts?
Use a voltage divider?
Please post a data sheet or supply the part number of the MOSFET.
SL2302 my mosfet. I would like to control with a PWM and change the brightness of the tape. but I could not find information on whether it is possible to use voltage mosfets through arduino low.
Per the SL2302, SL2302 Datasheet, SL2302 PDF - Slkor datsasheet, the Vgs /threshold/ voltage is 1.2V. It will accept +/-12V on Vgss, and at Vgs=5V, it will be completely on with a Rds=45mOhm. And per Fig 5, will switch Vds=1.2 at plenty of amps.
Hi, @arm0id
Welcome to the forum.
What are the specs of your LED strip.
Can you please post link to where you purchased it and/or specs/data.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
No voltage divider required on the gate. Connect directly to a 5V output or include a gate resistor. It has been debated here many times about the use of a series resistor between the Arduino output and gate to limit the gate capacitance charging current. I always use a 180Ω resistor, for 5V outputs, to be on the safe side.
LEDs are very forgiving load. Decreasing switching speed when the load is inductive is far from safe.
