Hello everyone,
I am new to programming and i was trying to control the direction of two motors with light. However my code is not working. Could you guys please see what the problem could be?
// motor One
int enA = 9;
int in1 = 8;
int in2 = 7;
// motor Two
int enB = 3;
int in3 = 5;
int in4 = 4;
int sensorPinRight = 2; // Right sensor pin
int sensorPinLeft = 3; // Left sensor pin
int sensorPinForward = 0; // Front sensor pin
int sensorPinBackward = 1; // Back sensor Pin
int lightReadingRight;
int lightToleranceRight = 500; // Sensor reading needed to trigger right turn
int lightReadingLeft;
int lightToleranceLeft = 500; // Sensor reading needed to trigger left turn
int lightReadingForward;
int lightToleranceForward = 500; // Sensor reading needed to trigger front turn
int lightReadingBackward;
int lightToleranceBackward = 500; // Sensor reading needed to trigger back turn
int readingDelay = 100; // Delay between readings
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
//Uncomment serial feed for calibration purposes
// Uncomment the serial print lines for calibration purposes
// Take reading from right sensor
lightReadingRight = analogRead(sensorPinRight);
Serial.print("Right Sensor Reading :");
Serial.println(lightReadingRight);
// Take reading from left sensor
lightReadingLeft = analogRead(sensorPinLeft);
Serial.print("Left Sensor Reading :");
Serial.println(lightReadingLeft);
// Take reading from front sensor
lightReadingForward = analogRead(sensorPinForward);
Serial.print("Front Sensor Reading :");
Serial.println(lightReadingForward);
//Take reading from back sensor
lightReadingBackward = analogRead(sensorPinBackward);
Serial.print("Back Sensor Reading :");
Serial.println(lightReadingBackward);
// Move forward if enought light is detected from front sensor
if (lightReadingForward > lightToleranceForward)
// motor A
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
analogWrite(enA,200);
// motor B
digitalWrite(in3,HIGH);
digitalWrite(in4,LOW);
analogWrite(enB,200);
delay(readingDelay);
// now turn off motors
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
// Turn right if enough light is detected from right sensor
if (lightReadingRight > lightToleranceRight)
digitalWrite(in1,LOW);
digitalWrite(in2, HIGH);
digitalWrite(in4, HIGH);
// Turn left if enough light is detected from left sensor
if (lightReadingLeft > lightToleranceLeft)
// Stop
//Turn back if enough light is detected from the backward direction
digitalWrite(in2,HIGH);
digitalWrite(in3,LOW);
digitalWrite(in4,HIGH);
// Stop
