About my programing
Hello friends, my project is to unlock using a piece of esp32 dvi v1
And pn532 and I have a problem
In programming, it is (no matching function for call to pn532 .).
This is an introduction to programming
The rest is correct
#include <Wire.h>
#include <PN532_SPI.h>//include to use the Witty Fox NFC board
#include <SPI.h>
#include <NDEF.h>
#include <NDEF_TXT.h>
#include "PN532.h"
#include <PN532_I2C.h>
#define PN532i2c_BOOSTERPACK_RESET_PIN 25 //reset pin of NFC board connected to GPIO
#define PN532i2c_BOOSTERPACK_IRQ_PIN 26 //interrupt pin of NFC board connected to GPIO
PN532 nfc(PN532i2c_BOOSTERPACK_RESET_PIN, PN532i2c_BOOSTERPACK_IRQ_PIN);
Likely caused by an error in your program code.
Can you fixed please
This is my programming
#include <Wire.h>
#include <PN532_SPI>
#include <NDEF.h>
NDEF_TXT msg;
uint8_t buf[512];
String password = "Robocraze"; //declaration of the password which will unlock the door
void DumpSRAM();
pinMode(2, OUTPUT); //pin connected to on-board LED
pinMode(13, OUTPUT); //pin connected to input of Relay
Serial.println("Initializing I2C-");
Wire.begin();
Serial.println("Initializing NFC Tag-");
nfc.begin();
Serial.println("Activating NFC transceiver-");
nfc.enable();
Serial.println("Now waiting for NFC master to post a Text block.");
msg.setPayloadBuffer(buf, 512); // Set allocation buffer used to store incoming NDEF data
digitalWrite(13, HIGH);
if (nfc.loop())
// If nfc.loop() returns true, nfc.disable() is implicitly run...
if (nfc.isError())
  Serial.println("NFC transceiver reports its SRAM contents do not contain valid NDEF data.");
  DumpSRAM();
if (nfc.wasRead())
  Serial.println("NDEF tag was read!");
if (nfc.available())
  Serial.print("NFC master has written a new tag! ");
  uint16_t len = nfc.getDataLength();
  Serial.print(len);
  Serial.println(" bytes");
  Serial.println("Assuming data is NDEF TEXT; importing-");
  int ret = msg.import(nfc);
  if (ret < 0)
    Serial.println("ERROR importing NDEF TEXT data. SRAM dump:");
    DumpSRAM();
    Serial.println("Success!");
    Serial.print("Language code: ");
    Serial.println(msg.getLanguage());
    Serial.println("Text block:");
String Data = msg.getText();
    Serial.println(Data);
    if (Data == password) //door will only unlock if the received message matches with the password set in the beginning
      int i;
      for (i = 0; i < 5; i++)
        digitalWrite(13, LOW); //door will unlock for approximately 5 seconds
//blink onboard LED when the door is unlocked
        digitalWrite(2, HIGH);
        digitalWrite(2, LOW);
i = 0;
  nfc.flush();
nfc.enable();
void DumpSRAM()
uint8_t sram[128];
nfc.readSRAM(0x0000, sram, 128);
for (int i = 0; i < 128; i++)
if (sram[i] < 0x10)
  Serial.print('0');
Serial.print(sram[i], HEX);
Serial.print(' ');
if (i % 9 == 8)
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
You can go back and fix your original post by highlighting the code and clicking the </> in the menu bar.
code tags new
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
#include <Wire.h>
#include <NDEF.h>
NDEF_TXT msg;
uint8_t buf[512];
void DumpSRAM();
  Wire.begin();
  nfc.begin();
  nfc.enable();
  if (nfc.loop())
    if (nfc.isError())
      DumpSRAM();
    if (nfc.wasRead())
      Serial.print(len);
      if (ret < 0)
        DumpSRAM();
          int i;
i = 0;
      nfc.flush();
    nfc.enable();
void DumpSRAM()
  uint8_t sram[128];
    if (sram[i] < 0x10)
      Serial.print('0');
    Serial.print(' ');
    if (i % 9 == 8)
The message error is (no function call PN532)
I bet the error message is a little longer than that. At least I'd expect a line number to be in there somewhere. Please post the entire error message.
Why
Do
You
Have
So
Much
White
Space
In
Your
Program?
the error massage
Arduino: 1.8.19 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
sketch_apr02a:21:72: error: no matching function for call to 'PN532::PN532(int, int)'
In file included from C:\Users\Huss-\Desktop\sketch_mar31a\sketch_mar31a\sketch_apr02a\sketch_apr02a.ino:11:0:
C:\Users\Huss-\Desktop\arduino-1.8.19-windows\libraries\PN532/PN532.h:130:5: note: candidate: PN532::PN532(PN532Interface&)
     PN532(PN532Interface &interface);
C:\Users\Huss-\Desktop\arduino-1.8.19-windows\libraries\PN532/PN532.h:130:5: note:   candidate expects 1 argument, 2 provided
C:\Users\Huss-\Desktop\arduino-1.8.19-windows\libraries\PN532/PN532.h:127:7: note: candidate: constexpr PN532::PN532(const PN532&)
 class PN532
C:\Users\Huss-\Desktop\arduino-1.8.19-windows\libraries\PN532/PN532.h:127:7: note:   candidate expects 1 argument, 2 provided
C:\Users\Huss-\Desktop\arduino-1.8.19-windows\libraries\PN532/PN532.h:127:7: note: candidate: constexpr PN532::PN532(PN532&&)
C:\Users\Huss-\Desktop\sketch_mar31a\sketch_mar31a\sketch_apr02a\sketch_apr02a.ino: In function 'void setup()':
sketch_apr02a:63:7: error: 'class PN532' has no member named 'enable'
   nfc.enable();
C:\Users\Huss-\Desktop\sketch_mar31a\sketch_mar31a\sketch_apr02a\sketch_apr02a.ino: In function 'void loop()':
sketch_apr02a:85:11: error: 'class PN532' has no member named 'loop'
   if (nfc.loop())
sketch_apr02a:91:13: error: 'class PN532' has no member named 'isError'
     if (nfc.isError())
sketch_apr02a:101:13: error: 'class PN532' has no member named 'wasRead'
     if (nfc.wasRead())
sketch_apr02a:109:13: error: 'class PN532' has no member named 'available'
sketch_apr02a:115:26: error: 'class PN532' has no member named 'getDataLength'
sketch_apr02a:125:31: error: no matching function for call to 'NDEF_TXT::import(PN532&)'
In file included from C:\Users\Huss-\Desktop\sketch_mar31a\sketch_mar31a\sketch_apr02a\sketch_apr02a.ino:9:0:
C:\Users\Huss-\Documents\Arduino\libraries\RF430CL-master/NDEF_TXT.h:76:13: note: candidate: virtual int NDEF_TXT::import(Stream&)
         int import(Stream &s);  // For reading from a suitable NFC passive device, or any form of stream
C:\Users\Huss-\Documents\Arduino\libraries\RF430CL-master/NDEF_TXT.h:76:13: note:   no known conversion for argument 1 from 'PN532' to 'Stream&'
sketch_apr02a:185:11: error: 'class PN532' has no member named 'flush'
       nfc.flush();
sketch_apr02a:189:9: error: 'class PN532' has no member named 'enable'
     nfc.enable();
C:\Users\Huss-\Desktop\sketch_mar31a\sketch_mar31a\sketch_apr02a\sketch_apr02a.ino: In function 'void DumpSRAM()':
sketch_apr02a:205:7: error: 'class PN532' has no member named 'readSRAM'
exit status 1
option enabled in File -> Preferences.
Did you read the error message?
The error messages are quite clear with what you need to fix.
Anyways, post a link to the library you are using. The Adafruit library is the one I keep finding, of course I am lazy and don't want to do your research for you.
And could you, please, use code tags?
see the different
This program is correct
#include <Wire.h>
#include <RF430CL.h> //include to use the Witty Fox NFC board
#include <NDEF.h>
#define RF430CL330H_BOOSTERPACK_RESET_PIN 25 //reset pin of NFC board connected to GPIO
#define RF430CL330H_BOOSTERPACK_IRQ_PIN 26 //interrupt pin of NFC board connected to GPIO
RF430 nfc(RF430CL330H_BOOSTERPACK_RESET_PIN, RF430CL330H_BOOSTERPACK_IRQ_PIN);
NDEF_TXT msg;
uint8_t buf[512];
void DumpSRAM();
  Wire.begin();
  nfc.begin();
  nfc.enable();
  if (nfc.loop())
    if (nfc.isError())
      DumpSRAM();
    if (nfc.wasRead())
      Serial.print(len);
      if (ret < 0)
        DumpSRAM();
          int i;
i = 0;
      nfc.flush();
    nfc.enable();
void DumpSRAM()
  uint8_t sram[128];
    if (sram[i] < 0x10)
      Serial.print('0');
    Serial.print(' ');
    if (i % 9 == 8)
This is not correct
#include <Wire.h>
#include <PN532_I2C>
#include <NDEF.h>
NDEF_TXT msg;
uint8_t buf[512];
void DumpSRAM();
  Wire.begin();
  nfc.begin();
  nfc.enable();
  if (nfc.loop())
    if (nfc.isError())
      DumpSRAM();
    if (nfc.wasRead())
      Serial.print(len);
      if (ret < 0)
        DumpSRAM();
          int i;
i = 0;
      nfc.flush();
    nfc.enable();
void DumpSRAM()
  uint8_t sram[128];
    if (sram[i] < 0x10)
      Serial.print('0');
    Serial.print(' ');
    if (i % 9 == 8)
Both of them  is the same but i change rf430 to pn532
It looks like you don't bother to read any replies.
I read it but im confused
Because im very bad for programming
So i want helllp
Because tomorrow my presentation for my project
My project is NFC BASED SECURITY DOOR LOCK
Using pn532 and esp32 devi v1
