About NRF24L01 sending and receiving control
Testing Robin2's SimpleTx.ino and SimpleRx.ino.
if I like to:
  1. Tx send '5' for 3 times;
  2. let the Rx side light on a LED for 2 second when received '5' and without receiving any data during.
    what can I do?
    Thanks
    Adam
Tx:
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
    Serial.println("SimpleTx Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.setRetries(3,5); // delay, count
    radio.openWritingPipe(slaveAddress);
    currentMillis = millis();
    if (currentMillis - prevMillis >= txIntervalMillis) {
        send();
        prevMillis = millis();
void send() {
    bool rslt;
    rslt = radio.write( &dataToSend, sizeof(dataToSend) );
        // Always use sizeof() as it gives the size as the number of bytes.
        // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print("Data Sent ");
    Serial.print(dataToSend);
    if (rslt) {
        Serial.println("  Acknowledge received");
        updateMessage();
    else {
        Serial.println("  Tx failed");
void updateMessage() {
        // so you can see that new data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
    dataToSend[8] = txNum;
Rx:
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
    Serial.println("SimpleRx Starting");
    radio.begin();
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.startListening();
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        newData = true;
void showData() {
    if (newData == true) {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        newData = false;
I don't know why to send "5" three times. One is enough.
Here the transmitter send a "5" every 5 seconds.
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
char dataToSend[10] = "5";  // must be a string or array hence ""
unsigned long txIntervalMillis = 5000; // send once per 5 seconds
   radio.begin();
   radio.setRetries(3, 5); // delay, count
      send();
void send()
   bool rslt;
   if (rslt)
If the receiver gets the "5" it turns on an LED on pin 13 for 2 seconds.
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
#define ledPin  13
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
   pinMode(ledPin, OUTPUT);
   radio.begin();
   getData();
   showData();
void getData()
      newData = true;
void showData()
      if (dataReceived[0] == '5')
         digitalWrite(ledPin, HIGH);
         delay(2000);
         digitalWrite(ledPin, LOW);
      newData = false;
Great!
Thank you groundFungus.
