about range of BLE
hi guys. I have a quick question about the BLE module. It's that possible to set up the range of BLE module for a special application?
No. The range is defined by the hardware and software that you can't configure.
what do you mean the software?
MikeLuo:
What do you think makes the BLE device work? It's hardware and software, just like the Arduino.
Sorry, I should make the statement clear enough. I am using BLE 4.0 module, such as HM-10 or HM-11. I would like using Arduino to access it. I wonder if we can setup the rang of BLE module with Arduino.
MikeLuo:
I believe English is a second language. Are you asking about reducing the the distance the bluetooth will transmit? If that is the case, why would you want to do that? I don't believe you can, and I don't believe there should be a need to.
I see, thank you guy, and yes, English is my second language, I am suffering form not understanding this language clearly recently. Thank for you guys' patience. :slight_smile:
OK, here is some information on BLE
http://letsmakerobots.com/node/38009
