About "SERIAL_TX_BUFFER_SIZE" and "SERIAL_RX_BUFFER_SIZE"
I need receive more than 64 byte data,but always loss....
#include <SoftwareSerial.h>
#define SERIAL_TX_BUFFER_SIZE 128
#define SERIAL_RX_BUFFER_SIZE 128
void setup() {Serial.begin(115200);}
if(Serial.available()> 0)
String s = "";
while (Serial.available() )
char c = Serial.read();
s += c;
delay(10);
Serial.println(s);
s = "" ;
If you loose data, you will need to read faster. Get rid of the delay.
Find Robin's serial input basics thread to get ideas how to properly read serial data; you can modify it to use SoftwareSerial.
sterretje:
But not like the OP tried in the posted sketch, which does not use SoftwareSerial, it only includes it.
Thanks for that.
sterretje:
This question is about "BUFFER_SIZE" (#define SERIAL_RX_BUFFER_SIZE 128)
I send 00 ~ 34 total 70 byte
but just receive 64 byte (00~31)
(C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h)
The initial values are as follows:
#if !defined(SERIAL_TX_BUFFER_SIZE)
#if ((RAMEND - RAMSTART) < 1023)
#define SERIAL_TX_BUFFER_SIZE 16
#else
#define SERIAL_TX_BUFFER_SIZE 64
#endif
#endif
#if !defined(SERIAL_RX_BUFFER_SIZE)
#define SERIAL_RX_BUFFER_SIZE 16
#else
#define SERIAL_RX_BUFFER_SIZE 64
#endif
#endif
Modify the code as follows and still only receive 64 byte . why??
#else
#endif
#endif
#else
#endif
#endif
It does not help to put that in your sketch; only the sketch knows about those #defines, they don't trickle down to the library files. You will need to modify that file that you showed in reply #4. No access to PC which file it exactly is.
And you're on the wrong track. For what you want to achieve, Robin's code shows the correct approach.
