About SPI_anything
Hi
I found Nick Gammon simple way to use SPI Gammon Forum : Electronics : Microprocessors : SPI - Serial Peripheral Interface - for Arduino by using SPI_anything. But there is master sends, slave receive. I want to use master request, slave sends. Does somebody have that example? Sorry for noob question...
something like this?
https://forum.arduino.cc/index.php?topic=488171.msg3331154#msg3331154
Not exactly. I want that slave reads some sensors and master requests those readings.
FiveO:
Ok but the the principle on that diagram still holds. just need to tweak the code a bit! :slight_smile:
so it pseudo code it would be something like this
MASTER:
//request slave to send sensor data
slave_reply = spi.transfer(READ_SENSOR); //at this point slave_reply will hold no valid data
do{
   delaymicroseconds(20);
   slave_reply = spi.transfer(0xFF);  //in your slave code it replies READING while its reading the sensors.
}while(spi_reply == READING);
if(spi_reply = DATA_READY){
 //if u now the number of sensor readings u getting can use a for loop
 //else implement on your slave side that is sends out how many sensor reading its got available
   spi_reply = spi.transfer(SEND_DATA);
   for(uint_8t i=0; i<ARR_SIZE;++i){
       sensor_data[i] = spi.transfer(SEND_DATA);
hope that helps
