Hi everyone.
The TTGOTetris-main got an external button on pin37 which designed for turning the blocks for TTGO.
question:
- testing shown the button works even put on other pin like 38?
- comment out the turning function, it still works same way, why?
- try to use this button to speed up the blocks, not work, why?
if (digitalRead(SpeedButton) == 0) {
game_speed = 80;
game_speed = 20;
how to fix please.
Thanks
Adam
#include <SPI.h>
#include <TFT_eSPI.h>
#include "tet.h"
TFT_eSPI tft = TFT_eSPI();
uint16_t BlockImage[8][12][12]; // Block
uint16_t backBuffer[220][110]; // GAME AREA
const int Length = 11; // the number of pixels for a side of a block
const int Width = 10; // the number of horizontal blocks
const int Height = 20; // the number of vertical blocks
int screen[Width][Height] = {0}; //it shows color-numbers of all positions
struct Point {
int X, Y;
struct Block {
Point square[4][4];
int numRotate, color;
Point pos; Block block;
int rot, fall_cnt = 0;
bool started = false, gameover = false;
boolean but_A = false, but_LEFT = false, but_RIGHT = false;
int game_speed = 20; // 25msec
Block blocks[7] = {
{ { {{ -1, 0}, {0, 0}, {1, 0}, {2, 0}}, {{0, -1}, {0, 0}, {0, 1}, {0, 2}},
{{0, 0}, {0, 0}, {0, 0}, {0, 0}}, {{0, 0}, {0, 0}, {0, 0}, {0, 0}}
}, 2, 1
{ { {{0, -1}, {1, -1}, {0, 0}, {1, 0}}, {{0, 0}, {0, 0}, {0, 0}, {0, 0}},
}, 1, 2
{ { {{ -1, -1}, { -1, 0}, {0, 0}, {1, 0}}, {{ -1, 1}, {0, 1}, {0, 0}, {0, -1}},
{{ -1, 0}, {0, 0}, {1, 0}, {1, 1}}, {{1, -1}, {0, -1}, {0, 0}, {0, 1}}
}, 4, 3
{ { {{ -1, 0}, {0, 0}, {0, 1}, {1, 1}}, {{0, -1}, {0, 0}, { -1, 0}, { -1, 1}},
}, 2, 4
{ { {{ -1, 0}, {0, 0}, {1, 0}, {1, -1}}, {{ -1, -1}, {0, -1}, {0, 0}, {0, 1}},
{{ -1, 1}, { -1, 0}, {0, 0}, {1, 0}}, {{0, -1}, {0, 0}, {0, 1}, {1, 1}}
}, 4, 5
{ { {{ -1, 1}, {0, 1}, {0, 0}, {1, 0}}, {{0, -1}, {0, 0}, {1, 0}, {1, 1}},
}, 2, 6
{ { {{ -1, 0}, {0, 0}, {1, 0}, {0, -1}}, {{0, -1}, {0, 0}, {0, 1}, { -1, 0}},
{{ -1, 0}, {0, 0}, {1, 0}, {0, 1}}, {{0, -1}, {0, 0}, {0, 1}, {1, 0}}
}, 4, 7
extern uint8_t tetris_img[];
#define GREY 0x5AEB
int pom = 0;
int pom2 = 0;
int pom3 = 0;
int pom4 = 0;
int score = 0;
int lvl = 1;
int leftButton = 0;
int rightButton = 35;
int SpeedButton = 37;
void setup(void) {
pinMode(SpeedButton, INPUT_PULLUP); /// originally this button turn the blockes same as the two on board buttons function.
/// here MDF for spped up
pinMode(leftButton, INPUT_PULLUP);
pinMode(rightButton, INPUT_PULLUP);
tft.init();
tft.setRotation(0);
tft.setSwapBytes(true);
tft.pushImage(0, 0, 135, 240, tet);
delay(3000);
tft.fillScreen(TFT_BLACK);
tft.drawLine(11, 19, 122, 19, GREY);
tft.drawLine(11, 19, 11, 240, GREY);
tft.drawLine(122, 19, 122, 240, GREY);
tft.drawString("SCORE:" + String(score), 14, 8, 1);
tft.drawString("LVL:" + String(lvl), 88, 8, 1);
//----------------------------// Make Block ----------------------------
make_block( 0, TFT_BLACK); // Type No, Color
make_block( 1, 0x00F0); // DDDD RED
make_block( 2, 0xFBE4); // DD,DD PUPLE
make_block( 3, 0xFF00); // D__,DDD BLUE
make_block( 4, 0xFF87); // DD_,_DD GREEN
make_block( 5, 0x87FF); // __D,DDD YELLO
make_block( 6, 0xF00F); // _DD,DD_ LIGHT GREEN
make_block( 7, 0xF8FC); // _D_,DDD PINK
PutStartPos(); // Start Position
for (int i = 0; i < 4; ++i) screen[pos.X +
block.square[rot][i].X][pos.Y + block.square[rot][i].Y] = block.color;
Draw(); // Draw block
if (gameover) {
if (digitalRead(leftButton) == 0)
for (int j = 0; j < Height; ++j)
for (int i = 0; i < Width; ++i)
screen[i][j] = 0;
gameover = false;
score = 0;
game_speed = 20;
lvl = 1;
Draw();
return;
if (gameover == false) {
Point next_pos;
int next_rot = rot;
GetNextPosRot(&next_pos, &next_rot);
ReviseScreen(next_pos, next_rot);
//M5.update();
delay(game_speed);
} // SPEED ADJUST
void Draw() { // Draw 120x240 in the center
for (int i = 0; i < Width; ++i) for (int j = 0; j < Height; ++j)
for (int k = 0; k < Length; ++k) for (int l = 0; l < Length; ++l)
backBuffer[j * Length + l][i * Length + k] = BlockImage[screen[i][j]][k][l];
tft.pushImage(12, 20, 110, 220, *backBuffer);
void PutStartPos() {
game_speed = 20;
pos.X = 4; pos.Y = 1;
block = blocks[random(7)];
rot = random(block.numRotate);
bool GetSquares(Block block, Point pos, int rot, Point* squares) {
bool overlap = false;
for (int i = 0; i < 4; ++i) {
Point p;
p.X = pos.X + block.square[rot][i].X;
p.Y = pos.Y + block.square[rot][i].Y;
overlap |= p.X < 0 || p.X >= Width || p.Y < 0 || p.Y >=
Height || screen[p.X][p.Y] != 0;
squares[i] = p;
return !overlap;
void GameOver() {
if (screen[i][j] != 0) screen[i][j] = 4;
gameover = true;
void ClearKeys() {
but_A = false;
but_LEFT = false;
but_RIGHT = false;
bool KeyPadLoop() {
if (digitalRead(leftButton) == 0 && digitalRead(rightButton) == 1) {
if (pom == 0)
pom = 1;
ClearKeys();
but_LEFT = true;
return true;
pom = 0;
if (digitalRead(rightButton) == 0 && digitalRead(leftButton) == 1) {
if (pom2 == 0)
pom2 = 1;
ClearKeys();
but_RIGHT = true;
return true;
pom2 = 0;
if(digitalRead(37)==0){
if(pom3==0)
{pom3=1;ClearKeys();but_A =true;return true;}
}else {pom3=0;}
game_speed = 80;
game_speed = 20;
if (digitalRead(rightButton) == 0 && digitalRead(leftButton) == 0) {
if (pom4 == 0)
pom4 = 1;
ClearKeys();
but_A = true;
return true;
pom4 = 0;
return false;
void GetNextPosRot(Point* pnext_pos, int* pnext_rot) {
bool received = KeyPadLoop();
if (but_LEFT) started = true;
if (!started) return;
pnext_pos->X = pos.X;
pnext_pos->Y = pos.Y;
if ((fall_cnt = (fall_cnt + 1) % 10) == 0) pnext_pos->Y += 1;
else if (1) {
if (but_LEFT) {
but_LEFT = false;
pnext_pos->X -= 1;
else if (but_RIGHT) {
but_RIGHT = false;
pnext_pos->X += 1;
else if (but_A) {
but_A = false;
*pnext_rot = (*pnext_rot + block.numRotate - 1) % block.numRotate;
void DeleteLine() {
for (int j = 0; j < Height; ++j) {
bool Delete = true;
for (int i = 0; i < Width; ++i) if (screen[i][j] == 0) Delete = false;
if (Delete)
score++;
if (score % 5 == 0)
lvl++;
game_speed = game_speed - 4;
for (int k = j; k >= 1; --k)
screen[i][k] = screen[i][k - 1];
void ReviseScreen(Point next_pos, int next_rot) {
Point next_squares[4];
block.square[rot][i].X][pos.Y + block.square[rot][i].Y] = 0;
if (GetSquares(block, next_pos, next_rot, next_squares)) {
screen[next_squares[i].X][next_squares[i].Y] = block.color;
pos = next_pos; rot = next_rot;
else {
if (next_pos.Y == pos.Y + 1) {
DeleteLine(); PutStartPos();
if (!GetSquares(block, pos, rot, next_squares)) {
GameOver();
Draw();
void make_block( int n , uint16_t color ) { // Make Block color
for ( int i = 0 ; i < 12; i++ ) for ( int j = 0 ; j < 12; j++ ) {
BlockImage[n][i][j] = color; // Block color
if ( i == 0 || j == 0 ) BlockImage[n][i][j] = 0; // TFT_BLACK Line
