about the DateTime.h
  1. where can download?
  2. got here: GitHub - PaulStoffregen/Time: Time library for Arduino , there is no datetime.h after unzip, why?
  3. how to make this file into .h : arduino/DateTimeStrings.h at master · hickey/arduino · GitHub
Thanks
Including the Time library will give you access to the functions in the DateStrings.cpp file.
DBMcDonald:
Thanks
I found the solution here and it works: Wiring.h missing in Arduino - Stack Overflow
Now comes error: The 'BYTE' keyword is no longer supported.
BUT...
this solution resulted some other troubles, the sketch related [wire.h] and LCD can't work unless reinstalled these two again. take a system time should be a simple job?
