I am using one Arduino Uno + Ethernet shield 1 from 2011 and recently one Arduino Mega + shield2 and in both case with IP address fixed, the problem (or anomaly?) is that these two devices are not identified by my modem router (= a LiveBox Orange), despite the fact that locally everything fine but I cannot remotely have a connection via my modem router as the 2 Arduinos are like a "phatom" ! So the shield 2 did not solve this problem. Is it a soft problem ? In it I put the fixed IP address and the Mac address of the shield. I wonder if someone has the same anomaly!
you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Post a schematic.
Post an image of your project.
Which Micro Controller are you using?
Is this simulator code?
Please describe the problem better then you just did.
