The example HMC5883L_processing
from library, got output need help please.
- why the Y axis number never change whatever move the board;
- the
headingDegrees = heading * 180/M_PI;
how to calculate that out?
for example the last line:-54.28:-3768.32:-513.36:273.61:229.00:229
how to get 273.61 from YAxis/XAxis*180/3.14 ?
Thanks
Adam
HMC5883L Triple Axis Digital Compass. Output for HMC5883L_processing.pde
Read more: http://www.jarzebski.pl/arduino/czujniki-i-sensory/3-osiowy-magnetometr-hmc5883l.html
GIT: https://github.com/jarzebski/Arduino-HMC5883L
Web: http://www.jarzebski.pl
(c) 2014 by Korneliusz Jarzebski
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
int previousDegree;
// Initialize HMC5883L
while (!compass.begin())
// Set measurement range
compass.setRange(HMC5883L_RANGE_1_3GA);
// Set measurement mode
compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Set data rate
compass.setDataRate(HMC5883L_DATARATE_30HZ);
// Set number of samples averaged
compass.setSamples(HMC5883L_SAMPLES_8);
// Set calibration offset. See HMC5883L_calibration.ino
compass.setOffset(0, 0);
long x = micros();
Vector norm = compass.readNormalize();
// Calculate heading
float heading = atan2(norm.YAxis, norm.XAxis);
// Set declination angle on your location and fix heading
// You can find your declination on: http://magnetic-declination.com/
// (+) Positive or (-) for negative
// For Bytom / Poland declination angle is 4'26E (positive)
// Formula: (deg + (min / 60.0)) / (180 / M_PI);
float declinationAngle = (4.0 + (26.0 / 60.0)) / (180 / M_PI);
heading += declinationAngle;
// Correct for heading < 0deg and heading > 360deg
if (heading < 0)
heading += 2 * PI;
if (heading > 2 * PI)
heading -= 2 * PI;
// Convert to degrees
float headingDegrees = heading * 180/M_PI;
// Fix HMC5883L issue with angles
float fixedHeadingDegrees;
if (headingDegrees >= 1 && headingDegrees < 240)
fixedHeadingDegrees = map(headingDegrees, 0, 239, 0, 179);
} else
if (headingDegrees >= 240)
fixedHeadingDegrees = map(headingDegrees, 240, 360, 180, 360);
// Smooth angles rotation for +/- 3deg
int smoothHeadingDegrees = round(fixedHeadingDegrees);
if (smoothHeadingDegrees < (previousDegree + 3) && smoothHeadingDegrees > (previousDegree - 3))
smoothHeadingDegrees = previousDegree;
previousDegree = smoothHeadingDegrees;
// Output
Serial.print(norm.XAxis);
Serial.print(":");
Serial.print(norm.YAxis);
Serial.print(":");
Serial.print(norm.ZAxis);
Serial.print(":");
Serial.print(headingDegrees);
Serial.print(":");
Serial.print(fixedHeadingDegrees);
Serial.print(":");
Serial.print(smoothHeadingDegrees);
// One loop: ~5ms @ 115200 serial.
// We need delay ~28ms for allow data rate 30Hz (~33ms)
delay(30);
