When I am compiling the code of QMC5883L, found that's a kind of complex as the code attached, not like the HMC5883L code seems simple, such as "#define OSR 0b00 " etc. and I even can't find more Arduino+QMC5883L code examples. Is this complex necessary for QMC5883L or just because not many people use it?
Thanks
Adam
// Reference the I2C Library
#include <Wire.h>
// Reference the QMC5883L Compass Library
#include <QMC5883L.h>
// configure the compass as reqiured
#define OSR 0b00 // over sampling rate set to 512. 0b01 is 256, 0b10 is 128 and 0b11 is 64
#define RNG 0b00 // Full Scale set to +/- 2 Gauss, 0b01 is +/- 8.
#define ODR 0b00 // output data rate set to 10Hz, 0b01 is 50Hz, 0b10 is 100Hz, 0b11 is 200Hz
#define MODE 0b01 // continuous measurement mode, 0b00 is standby
#define CR2 0b00000000 // control register 2: disable soft reset and pointer rollover, interrupt pin not enabled
#define RESETPERIOD 0b00000001 // datasheet recommends this be 1, not sure why!
// Store our compass as a variable.
QMC5883L compass;
// Record any errors that may occur in the compass.
int error = 0;
// Out setup routine, here we will configure the microcontroller and compass.
// Initialize the serial port.
Serial.println("Starting the I2C interface.");
Wire.begin(); // Start the I2C interface.
TWBR = 12; //Set the I2C clock speed to 400kHz - only works with Arduino UNO
Serial.println("Constructing new QMC5883L");
compass = QMC5883L(); // Construct a new HMC5883 compass.
// Check that a device responds at the compass address - don't continue if it doesn't -
do {
delay(100);
Wire.beginTransmission(QMC5883L_Address);
error = Wire.endTransmission();
if (error) Serial.println("Can't find compass - is it connected and powered up?");
} while (error);
// configure the control registers using static settings above
// compass autoranges, but starts in the mode given
compass.dataRegister.OSR_RNG_ODR_MODE = (OSR << 6) |(RNG << 4) | (ODR <<2) | MODE;
compass.dataRegister.CR2_INT_ENABLE = CR2;
compass.dataRegister.SET_RESET_PERIOD = RESETPERIOD;
Serial.println("Configuring QMC5883L - OSR 512, range +/-2 Gauss, ODR 10, Continuous");
error = compass.Configure(compass.dataRegister); // use static settings from above - can access register data directly if required..
if(error != 0) // If there is an error, print it out, although no way to get error with this sensor....
Serial.println(compass.GetErrorText(error));
// Our main program loop.
// Retrive the raw values from the compass (not scaled).
MagnetometerRaw raw = compass.ReadRawAxis(&compass.dataRegister);
// Retrived the scaled values from the compass (scaled to the configured scale).
MagnetometerScaled scaled = compass.ReadScaledAxis(&compass.dataRegister);
// Values are accessed like so:
int MilliGauss_OnThe_XAxis = scaled.XAxis; // (or YAxis, or ZAxis)
// Calculate heading when the magnetometer is level, then correct for signs of axis.
// heading (degrees): 0 = +X, 90 = +Y, 180 = -X, 270 = -Y
float heading = atan2(scaled.YAxis, scaled.XAxis);
// Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Example is: 2� 37' W, which is 2.617 Degrees, or (which we need) 0.0456752665 radians, I will use 0.0457
// If you cannot find your Declination, comment out these two lines, your compass will be slightly off.
// float declinationAngle = 0.0457;
float declinationAngle = 0;
heading += declinationAngle;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*PI;
// Check for wrap due to addition of declination.
if(heading > 2*PI)
heading -= 2*PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI;
// Output the data via the serial port.
Output(raw, scaled, heading, headingDegrees);
// Normally we would either:
// 1. delay the application by 100ms to allow the loop to run at 10Hz (default bandwidth for the QMC5883L)
// 2. poll the dataready flag in the dataRegister.OVL_DRDY register
// 3. set the interrupt flat and set a hardware interrupt on the DRDY pin
// The first of these options is the easiest.
delay(100);
// Output the data down the serial port.
void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees)
Serial.print("Raw (X,Y,Z): (");
Serial.print(raw.XAxis);
Serial.print(", ");
Serial.print(raw.YAxis);
Serial.print(", ");
Serial.print(raw.ZAxis);
Serial.print(")\tScaled (X,Y,Z): (");
Serial.print(scaled.XAxis, 4);
Serial.print(", ");
Serial.print(scaled.YAxis, 4);
Serial.print(", ");
Serial.print(scaled.ZAxis, 4);
Serial.println(")");
Serial.print("Magnitude (0.25 to 0.6 on Earth surface): ");
Serial.print(sqrt(scaled.XAxis * scaled.XAxis + scaled.YAxis * scaled.YAxis + scaled.ZAxis * scaled.ZAxis));
Serial.print(" Heading: ");
Serial.print(headingDegrees);
Serial.print(" Bearing: ");
Serial.print(bearingDegrees(headingDegrees));
Serial.println(" (Degrees)");
// Cacluate bearing from heading.
// bearing 0 = Y pointing North, 90 = Y pointing E, 180 = Y pointing S, 270 = Y pointing W
float bearingDegrees(float headingDegrees) {
float bearing = 450 - headingDegrees;
if (bearing >= 360)
bearing -= 360;
return bearing;
here is a example of HMC5883L code:
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and HMC5883L must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MechaQMC5883.h" //// WAS: #include "HMC5883L.h"
// class default I2C address is 0x1E
// specific I2C addresses may be passed as a parameter here
// this device only supports one I2C address (0x1E)
HMC5883L mag;
int16_t mx, my, mz;
#define LED_PIN 13
bool blinkState = false;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// initialize serial communication
// (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
// it's really up to you depending on your project)
Serial.begin(38400);
// initialize device
Serial.println("Initializing I2C devices...");
mag.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(mag.testConnection() ? "HMC5883L connection successful" : "HMC5883L connection failed");
// configure Arduino LED for
pinMode(LED_PIN, OUTPUT);
// read raw heading measurements from device
mag.getHeading(&mx, &my, &mz);
// display tab-separated gyro x/y/z values
Serial.print("mag:\t");
Serial.print(mx); Serial.print("\t");
Serial.print(my); Serial.print("\t");
Serial.print(mz); Serial.print("\t");
// To calculate heading in degrees. 0 degree indicates North
float heading = atan2(my, mx);
if(heading < 0)
heading += 2 * M_PI;
Serial.print("heading:\t");
Serial.println(heading * 180/M_PI);
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
