Hello, I did not know electronic much, so I reading quite a long of books before starting using Arduino....
As I reading different books about Arduino, Something really bored me...
I found that IRF510 and TIP120 both can drive a DC motor, but what is the difference of them ?
(I knew that IRF510 is MOSFET abut TIP120 contain darlington transistor.) -
I know how to apply ohms law and calculate the resistors using is LED, however, I read some books and found that some circuit is using 220 ohms instead of 150 ohms (150 ohms should be the calculated value) , is it a great problem for it ? I found that even i use 330 Ohm the circuit seems still working.
Similar to the above questions, some book said the circuit should using 4K7 pot, but I found that using 5K pot still working, is there any rules of using resistors/ pot ?
Many thx.
