About uhf arduino code?
I am using JRD-100 - Arduino UHF-RFID Module
I have a hex code to start getting the hardware to work searching for the ID
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);// RX, TX
unsigned char incomingByte;
mySerial.begin(115200);
delay(200);
// 开机发多次轮询指令
byte message[] = {0xBB,0x00,0x27,0x00,0x03,0x22,0x27,0x10,0x83,0x7E};
mySerial.write(message, sizeof(message));
String value;
while (mySerial.available() > 0) {
incomingByte = mySerial.read();
value += String(incomingByte,HEX);
value += " ";
if(value.length() > 1){
Serial.print(value);
value = "";
delay(60);
he will show hex out
He wants to convert dec to calculate rrsi
The next field is to display the card number.
I want to make a circuit breaker sound if a certain card walks a certain distance. I would like to ask how to write the code to check the card number. thanks
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
0xBB <- start byte
0x022200 ?
0x11 <- data length (17)
0xXXXX <- RRSI? (little-endian)
0x00 ?
14 bytes of data (ID?)
0xXXXX <- Checksum
