Absence sensor
Hello!
I've been lurking around here looking for ideas on how to accomplish this little project but I've come up short. Basically I want to use my PIR sensor to keep an LED lit EXCEPT when there has been no detected movement for a defined period of time (probably around 2 minutes.) I need detected motion to light the LED, then start some sort of 2 minute timer that is re-started every time motion is detected again. The light would only go off after 2 minutes without detected motion. I've been trying to incorporate the sort of timer code I found here (http://popdevelop.com/2010/04/mastering-timer-interrupts-on-the-arduino/) with the example motion sensor alarm code that I cannot seem to find the source of. This however is not working :frowning: Does anyone have any ideas how this can be accomplished?
I would accomplish this with a state machine of sorts. Write your loop without delays so that on each pass, it checks the sensor. If there is movement, it resets a variable, say lastMoved, to the current millis() . If the current mills() - lastMoved is greater than 120000 (2 min), it turns on the led.
For an illustration of this concept, see the blink without delay sketch
This recent thread covered exactly what you want http://arduino.cc/forum/index.php/topic,68406.0.html
This is a typical problem called a "missing pulse detector", you don't even need an arduino if that is all you want to do.
Hardware:-
Arrange a pulse to discharge a charging capacitor using a transistor. When the charge reaches a certain level (using a voltage comparator) the output trips.
Software:-
Count up once a second. Each time you get a pulse reset the counter to zero. When counter reaches a certain value do your thing.
Wow, this is great stuff, I'll be able to get this up and running this weekend for sure. Thanks so much!
This is a good idea for sure. Just make sure that you don't use int as your datatype or you'll get some weird stuff going on. Sometimes when I write code quickly I'll do something dumb like that then when it doesn't work I'll scratch my head for a while and then eventually find the problem and feel like an idiot
