AC Current Sensor
Do i need to use the "Emonlib" library in my code to read the value on arduino or i can directly read the analog values by connecting with current sensor using following code? /* AnalogReadSerial Reads an analog input on pin 0, prints the result to the serial monitor. Attach the center pin of a potentiometer to pin A1, and the outside pins to +5V and ground.
This example code is in the public domain. */
// the setup routine runs once when you press reset: void setup() { // initialize serial communication at 9600 bits per second: Serial.begin(9600); }
// the loop routine runs over and over again forever: void loop() { // read the input on analog pin 0: int sensorValue = analogRead(A1); // print out the value you read: Serial.println(sensorValue); delay(1); // delay in between reads for stability }
That code does not call any functions of the library you refer to so no , you do not need to load it.
