AC Dimmer Light
Hello,
I brought this AC Light dimmer.
However, I can't get it to work. I use the example code that is given on their website (with some slight modifications) and connected my Arduino Uno to the Module.
I connected Zero-Crossing to Digital2 and PWM to Digital11. I also connected ACC and GND to 5V and GND on my Arduino.
I also connected a 220V LED Light bulb to the Load Connection and a Powerplug to AC-IN.
If I upload the code and plug in the Power, the light is always on without beeing dimmed.
There is small LED next to the PWM pin on the Module that is fading. So it seems like it should be working in principle.
Any Ideas Why it isn't working?
Simon
The code:
//ZERO----2
//DIMMER----11
int i;
int ZDpin=2;
void setup(){
  pinMode(2,INPUT);
  pinMode(11,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(10,OUTPUT);
void light(){
  delay(3);
  digitalWrite(10,1);
void loop(){
  i=digitalRead(10);
  digitalWrite(13,0);
  digitalWrite(10,0);
  attachInterrupt(digitalPinToInterrupt(ZDpin),light,RISING);
  delay(20);
  if(i==1){
    delay(3);
      digitalWrite(13,1);
      pwm();
void pwm()
  for (int a=10; a<=255;a++)
    analogWrite(11,a);
    delay(8);
    for (int a=255; a>=10;a--)
    analogWrite(11,a);
    delay(8);
  //delay(800);
Probably because the electronics inside your LED light bulb is keeping it from dimming.
Paul
Some LED lights are designed to be dimmed, many are not.
MarkT:
The LED that is linked to is described as being "dimmbar" (= dimmable).
Ententeich,
Is that the exact LED that you have, or for illustrative purposes only?
