AC power measurements
hi guy
i have porject to measure the AC power in base sataion of communication system (BTS) so i was looking for method to calculation the power factor.
I found Two ways:
1- three voltmeter method. like in this link : http://www.giangrandi.ch/electronics/cosphi/cosphi.shtml
or using crossing detector to calculator the difference time between voltage / current signals then using math with the frequency to find the power factor.
any advice. any one run any project like this before might share here so I can know more about those methods.
thanks
any one know high voltage AC sensors name for the first method.
This is not a trivial project - and you can buy such devices cheaply on ebay…
regards
Allan
Why do you want to calculate the power factor.
Yeah... If I needed very-accurate power/energy measurements I'd probably buy one. But if you want to build one, check out [u]OpenEnergryMonitor.Org[/u].
And if I was building something for "home use", I'd just measure current. If the power is coming from a power utility (in a modern country) the frequency is super-accurate, the voltage is very-close to nominal and stable, and if you're not running motors the power factor is very close to 1.0. That leaves current as the only unknown.
my project recommend that i want to know the power factor in the BTS equipment.
it's what they asked form me .
i know i can buy a device but i want to build it with arduino.
so can I measure the power factor or not
Do you need to do power factor correction like here? (more information needed).
amm it's something like that i will tell you what imagine that you have a supply lane with 220 v or 380 v single phase inter a big load
Its good to know the application. Reducing KVAR to lower electric bills? (still guessing)
