AC relay
Hey can anyone help with connecting a relay to control 220v AC power source?
is this relay ok
http://us.100y.com.tw/pdf_file/TRD-9VDC-FB-CL.pdf
I need a transistor right. 2n222 and a diode for safety?
Would love some help with this one!
Thanks,
Tim
A SSR (solid state relay) is the easiest and safest way.
4 pins, you feed it 5v on two and the other two switch the AC.
Example :
Great!
Thank you so much!
Can i put any protection into the circuit before it goes into the relay from the arduino or it should be ok?
TIm
A solid-state relay doesn't need a snubber diode like a coil relay does.
HTH
so i just connect the ground of the arduino to the - of the relay and the digital pin to the + and the the AC to the appropriate points on the relay, i actually looks like it can switch two things, no?
I found a similar one which i think i can buy at a store near my house,
It should be also ok no?
http://shop.conrad.at/ce/de/product/186635/ELEKTRONISCHESLASTRELAIS2A
Thanks again!
Yes, the Crydom should do the job, but note the rating - "2A 240V", so your load must not exceed about 500W, depending on load (resistive/inductive).
What are you controlling?
hey i am controlling three 90 Watt fans in a power board so it should be ok with 2A right?
