Hi
I got AC voltage sensor ZMPT101B and I need to use it to provide my arduino auno with AC voltage in order to be able to do some processing on it .
I have applied 220V AC but the output was around 2.4 V DC when I measure it by multi meter and no AC output coming out from the sensor at all.
I used arduino input A0
How did you measure that? As far as I found documentation about that Chinese stuff, it's a simple transformer with an opamp behind it. So you should get an Arduino compatible voltage to measure. The multimeter will average the output voltage (which is in the range 0-5V) so you should get 2.5V if the potentiometer is calibrated correctly. If you measure the voltage on the A0 pin fast enough, you'll see that it's showing a sinus curve.
Hi
As I know the multimeter must read the AC also but at apply the 220VAC the output of the sensor gives 2.5 DC .
i need to get AC output so i can apply it on the arduino
is this sensor gives AC or DC output ??
The multimeter expects AC in AC mode but the output of the module is a DC sinus wave that alternates between 0V and 5V. 2.5V AC would alternate between -3.5V and 3.5V (because the multimeter shows RMS). As the voltage never drops below 0 the multimeter will not show AC voltage.
