Hello!
I am having issues with voltage spikes from a 110VAC solenoid showing up on the Vcc of the Arduino MCU... causing resets and data corruption ![]()
The problem:
When I switch on/off the solenoids, there is a spike from the AC which I can see on the 5V board voltage. This spike is causing some problems (resets, data corruption) on the MCU. The relay switch circuit is diode protected... so I know it's the 110VAC voltage spike causing the problems.
I am trying to tackle the problem from 2 angles:
1: Reduce/eliminate the spike on the solenoid coil... I have tried Metal Oxide Varistors (MOV) and TVS diodes (transient voltage suppresor) from ACL to GND. This reduces the spike, but does not eliminate it.
2: Bolster the 5V regulator (to the MCU) in a way that it doesn't pass on the spike to the chip... larger capacitors around the regulator, etc.
I am having problems with BOTH of these solutions...
Does anyone know of the standard way to deal with AC solenoid spikes? I can't find much on the internet...
Also,
Do you know why the regulator doesn't regulate a ~100us spike (+/- 3V from 5V)?
I would really appreciate any help/direction you could provide...
Thank you very much,
Peter
