AC Voltage Monitor Faster Approach With Emonlib
Hello all!
I am working on Electricity Monitoring project which will monitor 3 sources 3-Phase AC (voltage only)
In the software it demands for 9 ADC pins and configurations. I am using Emonlib AC-AC adapter.
I need to create 9 EnergyMonitor instances
EnergyMonitor emon1;             // Create an instance
EnergyMonitor emon2;
EnergyMonitor emon3;
EnergyMonitor emon4;
EnergyMonitor emon5;
EnergyMonitor emon6;
EnergyMonitor emon7;
EnergyMonitor emon8;
EnergyMonitor emon9;
The problem lies in this:
  emon1.calcVI(20,1000);         // Calculate all. No. of half wavelengths (crossings), time-out
  emon2.calcVI(20,1000);
  emon3.calcVI(20,1000);
  emon4.calcVI(20,1000);
  emon5.calcVI(20,1000);
  emon6.calcVI(20,1000);
  emon7.calcVI(20,1000);
  emon8.calcVI(20,1000);
  emon9.calcVI(20,1000);
The higher the timeout the more stable and accurate the result is but with big disadvantage for one most needed feature. The most needed feature is that the system needs to migrate from one source to the another source without a human noticeable delay! If I only monitor the voltage without the transfer function I would say that everything is working perfectly.
The Results I got with timeout reduced to 50mS is also acceptable with me but still 50mS x9 is 450mS which is not acceptable for the transfer delay time! For now I am using only six instances (300mS) with Arduino Uno board how much more when I will use the complete nine instances (450mS)!
The final project will run on ATXMEGA128A3
Please I want to be advised if there is a way out. For example; can using an external A/D converter solve the is problem? Or is there another thing I can do in the library or something?
The big issue here is likely to be one of safety abs making the hardware for the high voltage section etc . To do that safely will cost .
You haven’t mentioned how you will measure current either - you will need to be sampling each variable a lot more than 100 times a second to “ reconstruct “ the waveform calculate phase , allow for load harmonics etc
If it was me I would use commercial 3ph meters that have a monitoring output ( for your Arduino ) - far far easier and Likely to be cheaper , safer, more accurate and easier to maintain .
Safety is observed. At least whoever that is alive and conscious of life thinks of safety first.
I am not reading current. Only the voltage is needed here.
As long as that person understands the risks and is suitable qualified …..I guess a lot of people who die think they know what they are doing
If you are only measuring voltage you could just use a transformer followed by a precision rectifier or .. as you need to buy the transformer , buy a voltage transducer , with a dc o/p instead - when packaged , similar price .
If loads etc are balanced you only need to measure one phase anyway .
Example
I understand the words but I'm not seeing the goal. Also I am not familiar with the Emonlib.
Can you state what your end result is?
i.e. monitor
  • average voltage
  • RMS voltage
  • looking of voltage peaks (of the RMS)
etc.
Note I doubt your voltage is even close to a perfect sine wave. This means the RMS value calculated from the average will not have some error.
Another question. "emon5.calcVI(20,1000);" implies there is some current value. Am I missing somthing here?
I'm not getting what your timeout delay is and why 50ms is ok but 450ms is not.
This is the code.
// EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3
#include "EmonLib.h"             // Include Emon Library
  emon1.voltage(2, 234.26, 1.7);  // Voltage: input pin, calibration, phase_shift
  emon1.current(1, 111.1);       // Current: input pin, calibration.
  emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
  emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
  float realPower       = emon1.realPower;        //extract Real Power into variable
  float apparentPower   = emon1.apparentPower;    //extract Apparent Power into variable
  float powerFActor     = emon1.powerFactor;      //extract Power Factor into Variable
  float supplyVoltage   = emon1.Vrms;             //extract Vrms into Variable
  float Irms            = emon1.Irms;             //extract Irms into Variable
This is the .cpp file:
  Emon.cpp - Library for openenergymonitor
  Created by Trystan Lea, April 27 2010
  GNU GPL
  modified to use up to 12 bits ADC resolution (ex. Arduino Due)
  by boredman@boredomprojects.net 26.12.2013
  Low Pass filter for offset removal replaces HP filter 1/1/2015 - RW
// Proboscide99 10/08/2016 - Added ADMUX settings for ATmega1284 e 1284P (644 / 644P also, but not tested) in readVcc function
//#include "WProgram.h" un-comment for use on older versions of Arduino IDE
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#endif
// Sets the pins to be used for voltage and current sensors
void EnergyMonitor::voltage(unsigned int _inPinV, double _VCAL, double _PHASECAL)
  inPinV = _inPinV;
  VCAL = _VCAL;
  PHASECAL = _PHASECAL;
  offsetV = ADC_COUNTS>>1;
void EnergyMonitor::current(unsigned int _inPinI, double _ICAL)
  inPinI = _inPinI;
  ICAL = _ICAL;
  offsetI = ADC_COUNTS>>1;
// Sets the pins to be used for voltage and current sensors based on emontx pin map
void EnergyMonitor::voltageTX(double _VCAL, double _PHASECAL)
  inPinV = 2;
  VCAL = _VCAL;
void EnergyMonitor::currentTX(unsigned int _channel, double _ICAL)
  if (_channel == 1) inPinI = 3;
  if (_channel == 2) inPinI = 0;
  if (_channel == 3) inPinI = 1;
  ICAL = _ICAL;
// emon_calc procedure
// Calculates realPower,apparentPower,powerFactor,Vrms,Irms,kWh increment
// From a sample window of the mains AC voltage and current.
// The Sample window length is defined by the number of half wavelengths or crossings we choose to measure.
void EnergyMonitor::calcVI(unsigned int crossings, unsigned int timeout)
  #if defined emonTxV3
  int SupplyVoltage=3300;
  #else
  int SupplyVoltage = readVcc();
  #endif
  unsigned int crossCount = 0;                             //Used to measure number of times threshold is crossed.
  unsigned int numberOfSamples = 0;                        //This is now incremented
  // 1) Waits for the waveform to be close to 'zero' (mid-scale adc) part in sin curve.
  unsigned long start = millis();    //millis()-start makes sure it doesnt get stuck in the loop if there is an error.
  while(1)                                   //the while loop...
    startV = analogRead(inPinV);                    //using the voltage waveform
    if ((startV < (ADC_COUNTS*0.55)) && (startV > (ADC_COUNTS*0.45))) break;  //check its within range
    if ((millis()-start)>timeout) break;
  // 2) Main measurement loop
  start = millis();
  while ((crossCount < crossings) && ((millis()-start)<timeout))
    numberOfSamples++;                       //Count number of times looped.
    lastFilteredV = filteredV;               //Used for delay/phase compensation
    // A) Read in raw voltage and current samples
    sampleV = analogRead(inPinV);                 //Read in raw voltage signal
    sampleI = analogRead(inPinI);                 //Read in raw current signal
    // B) Apply digital low pass filters to extract the 2.5 V or 1.65 V dc offset,
    //     then subtract this - signal is now centred on 0 counts.
    offsetV = offsetV + ((sampleV-offsetV)/1024);
    filteredV = sampleV - offsetV;
    offsetI = offsetI + ((sampleI-offsetI)/1024);
    filteredI = sampleI - offsetI;
    // C) Root-mean-square method voltage
    sqV= filteredV * filteredV;                 //1) square voltage values
    sumV += sqV;                                //2) sum
    // D) Root-mean-square method current
    sqI = filteredI * filteredI;                //1) square current values
    sumI += sqI;                                //2) sum
    // E) Phase calibration
    phaseShiftedV = lastFilteredV + PHASECAL * (filteredV - lastFilteredV);
    // F) Instantaneous power calc
    instP = phaseShiftedV * filteredI;          //Instantaneous Power
    sumP +=instP;                               //Sum
    // G) Find the number of times the voltage has crossed the initial voltage
    //    - every 2 crosses we will have sampled 1 wavelength
    //    - so this method allows us to sample an integer number of half wavelengths which increases accuracy
    lastVCross = checkVCross;
    if (sampleV > startV) checkVCross = true;
                     else checkVCross = false;
    if (numberOfSamples==1) lastVCross = checkVCross;
    if (lastVCross != checkVCross) crossCount++;
  // 3) Post loop calculations
  //Calculation of the root of the mean of the voltage and current squared (rms)
  //Calibration coefficients applied.
  double V_RATIO = VCAL *((SupplyVoltage/1000.0) / (ADC_COUNTS));
  Vrms = V_RATIO * sqrt(sumV / numberOfSamples);
  double I_RATIO = ICAL *((SupplyVoltage/1000.0) / (ADC_COUNTS));
  Irms = I_RATIO * sqrt(sumI / numberOfSamples);
  //Calculation power values
  realPower = V_RATIO * I_RATIO * sumP / numberOfSamples;
  apparentPower = Vrms * Irms;
  powerFactor=realPower / apparentPower;
  //Reset accumulators
  sumV = 0;
  sumI = 0;
  sumP = 0;
double EnergyMonitor::calcIrms(unsigned int Number_of_Samples)
  #else
  #endif
  for (unsigned int n = 0; n < Number_of_Samples; n++)
    // Digital low pass filter extracts the 2.5 V or 1.65 V dc offset,
    //  then subtract this - signal is now centered on 0 counts.
    offsetI = (offsetI + (sampleI-offsetI)/1024);
    // Root-mean-square method current
    // 1) square current values
    // 2) sum
    sumI += sqI;
  Irms = I_RATIO * sqrt(sumI / Number_of_Samples);
  sumI = 0;
  return Irms;
void EnergyMonitor::serialprint()
  Serial.print(realPower);
  Serial.print(' ');
  Serial.print(apparentPower);
  Serial.print(' ');
  Serial.print(Vrms);
  Serial.print(' ');
  Serial.print(Irms);
  Serial.print(' ');
  Serial.print(powerFactor);
  Serial.println(' ');
  delay(100);
//thanks to http://hacking.majenko.co.uk/making-accurate-adc-readings-on-arduino
//and Jérôme who alerted us to http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
long EnergyMonitor::readVcc() {
  long result;
  //not used on emonTx V3 - as Vcc is always 3.3V - eliminates bandgap error and need for calibration http://harizanov.com/2013/09/thoughts-on-avr-adc-accuracy/
  #if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328__) || defined (__AVR_ATmega328P__)
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__)
  ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #elif defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || defined(__AVR_AT90USB1286__)
  ADCSRB &= ~_BV(MUX5);   // Without this the function always returns -1 on the ATmega2560 http://openenergymonitor.org/emon/node/2253#comment-11432
  #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
  ADMUX = _BV(MUX5) | _BV(MUX0);
  #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
  ADMUX = _BV(MUX3) | _BV(MUX2);
  #endif
  #if defined(__AVR__)
  delay(2);                                        // Wait for Vref to settle
  ADCSRA |= _BV(ADSC);                             // Convert
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = READVCC_CALIBRATION_CONST / result;  //1100mV*1024 ADC steps http://openenergymonitor.org/emon/node/1186
  return result;
  #elif defined(__arm__)
  return (3300);                                  //Arduino Due
  #else
  return (3300);                                  //Guess that other un-supported architectures will be running a 3.3V!
  #endif
This is the header file
  Emon.h - Library for openenergymonitor
  GNU GPL
#ifndef EmonLib_h
#define EmonLib_h
#else
#endif
// define theoretical vref calibration constant for use in readvcc()
// 1100mV*1024 ADC steps http://openenergymonitor.org/emon/node/1186
// override in your code with value for your specific AVR chip
// determined by procedure described under "Calibrating the internal reference voltage" at
// http://openenergymonitor.org/emon/buildingblocks/calibration
#ifndef READVCC_CALIBRATION_CONST
#define READVCC_CALIBRATION_CONST 1126400L
#endif
// to enable 12-bit ADC resolution on Arduino Due,
// include the following line in main sketch inside setup() function:
//  analogReadResolution(ADC_BITS);
// otherwise will default to 10 bits, as in regular Arduino-based boards.
#if defined(__arm__)
#define ADC_BITS    12
#else
#define ADC_BITS    10
#endif
#define ADC_COUNTS  (1<<ADC_BITS)
class EnergyMonitor
  public:
    void voltage(unsigned int _inPinV, double _VCAL, double _PHASECAL);
    void current(unsigned int _inPinI, double _ICAL);
    void voltageTX(double _VCAL, double _PHASECAL);
    void currentTX(unsigned int _channel, double _ICAL);
    void calcVI(unsigned int crossings, unsigned int timeout);
    double calcIrms(unsigned int NUMBER_OF_SAMPLES);
    void serialprint();
    long readVcc();
    //Useful value variables
    double realPower,
      apparentPower,
      powerFactor,
      Vrms,
      Irms;
  private:
    //Set Voltage and current input pins
    unsigned int inPinV;
    unsigned int inPinI;
    //These need to be set in order to obtain accurate results
    double VCAL;
    double ICAL;
    double PHASECAL;
    // Variable declaration for emon_calc procedure
    int sampleV;                        //sample_ holds the raw analog read value
    int sampleI;
    double lastFilteredV,filteredV;          //Filtered_ is the raw analog value minus the DC offset
    double filteredI;
    double offsetV;                          //Low-pass filter output
    double offsetI;                          //Low-pass filter output
    double phaseShiftedV;                             //Holds the calibrated phase shifted voltage.
    double sqV,sumV,sqI,sumI,instP,sumP;              //sq = squared, sum = Sum, inst = instantaneous
    int startV;                                       //Instantaneous voltage at start of sample window.
    boolean lastVCross, checkVCross;                  //Used to measure number of times threshold is crossed.
#endif
The "emon5.calcVI(20,1000);" is supposed to be applied to current calculations also but I don't need current here.
The device has 3 sources as I said all 3-phase. Here, The grid is not consistence. There are some situation where:
  • There may be no voltage in L1 or L2 or L3
  • One or two or all of the lines may be High or low
  • The private generator set is more consistence.
    The device will detect each conditions and display the results on LCD. LVD or HVD will take place when necessary,
In this device Source 1 is City Grid, Source 2 is Generator 1 (The main Gen set), while source 3 is the emergency Generator 2 less in KVA than Generator 2.
If the Generator 1 is on and and Generator 2 is started the device will change over to Generator 2 after 15 seconds and switched of the Generator 1 after another 15 seconds and vise versa. Then while any of these generator is on while the city grid is returned, the city grid will change over at elapse of 15 seconds after its voltage levels has been passed by the device.
During all the time of changing over to sources, the connected electrical equipment and devices are not stopped.
Coming back to the problems I am having now; This code inserts an unacceptable delay during the change over. If I monitor one or two ADCs, the delay is insignificant but monitoring the six ADCs now introduce the delay. I want to know using A/D Converter like AD7173 will be better or worst or no change?
I understand,
Tell me what are you using to monitor the phase voltages? i.e. a wall wart with DC output or a wall wart with AC output or just a transformer?
240VAC to 9VAC Transformer
This is my sensor setup. For reading and display purposes, the result is acceptable but the delay during source transfer is not acceptable
I am using 240VAC to 9VAC transformer for now.
Though I used OPA340 to buffer the output. As I said the measurements is not my problem but the lagging delay when extend the reading from two to signals to 6 signals. I even got good reading at the 6 signal inputs but the lagging delay thing
I looked at the Emonlib and can see when you call "emonX.calcVI(20,1000)" it reads both voltage and current, so you are loosing time here as the readings are double what you need.
Try the "calcIrms" function (see the example) only set the inputs so the voltage is actually read. It should make the measurements faster.
I have tweaked the code to use "calcIrms" function but it does not display any result. It only works for current
Please can you help me with another code that can do this besides emonlib.
I'm not really a good programmer but sometimes not bad at troubleshooting.
So when you say the calcirms function does not display results, are you trying to print current or voltage?
Did you try the current only example but set the input for voltage? There should be no difference to the code as both are connected to an a/d input.
I later tried it this way it worked but it is the same
Remove the emon1.serialprint(); statement and only print the minimum info you need. If still not fast enough print nothing and see if that is better.
