i will use the Ac4790 transceiver on Arduino.
i must choose a antenna. Which antenna should i use ? :-/
Thank you
Thank you
Thanks, i couldnt see dbi gain ?
do you know the range of AC4790-200 M without antenna,
and AC needs a MMCX antenna, but Is it possible to use RPSMA antenna
and is there any interest between range and output power ?
I don't think "interest" is the right word. there is a connection between output power and range. Increase the power and you will increase the range.
I don't know but probably close to zero.
You are right Grumpy_Mike ,
Thanks
good day !
