Accel+Gyro+Baro+Mag sensor
I have one of these http://www.electrodragon.com/product/ey88-10dof-motion-sensor-accelgyrobaromag/
Does anyone know how to wire it up or in what form the data is sent?
The board contains three seperate chips: MPU6050, BPM085 and HMC5883.
You can connect to the chips via I2C. The I2C is 5V compatible, so it will work with an Arduino Uno.
Which Arduio board are you using ?
For the Arduino Uno:
Vin to the 5V pin of the Arduino Uno.
GND to GND.
SDA to SDA or pin A4.
SCL to SCL or pin A5.
After that, run the i2c_scanner to see if all three chips are detected.
http://playground.arduino.cc/Main/I2cScanner
I think that board doesn't have a pulldown for the AD0 of the MPU-6050. You can connect G_AD0 to GND.
