I am new to Arduino and trying to make a project on Accident detect and reporting system using ACCELEROMETER ADXL345 ,GPS NEO 6M ,GSM 800 but unable to them together . The Gsm and Adxl345 works fine together but not adxl345 and gps neo6m . When i upload the individual code for both Adxl345 and GPS while all three modules are connected it works but when i upload the code for all three component it the GPS and accelerometer doesn't work . PLEASE HELP !
the following is the complete code for the same.
#include <Wire.h>
#include <TinyGPS++.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include<SoftwareSerial.h>
SoftwareSerial Serial1(2,3); //make RX arduino line is pin 2, make TX arduino line is pin 3.
int RXPin = 10;
int TXPin = 11;
int GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial gpsSerial(RXPin, TXPin);
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
int xsample=0;
int ysample=0;
int zsample=0;
#define samples 10
#define minVal -50
#define MaxVal 50
int i=0;
float latitude=0;
float logitude=0;
void initModule(String cmd, char *res, int t)
while(1)
Serial.println(cmd);
Serial1.println(cmd);
delay(100);
while(Serial1.available()>0)
if(Serial1.find(res))
Serial.println(res);
delay(t);
return;
Serial.println("Error");
delay(t);
Serial1.begin(9600);
gpsSerial.begin(GPSBaud);
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
accel.setRange(ADXL345_RANGE_16_G);
Serial.println("Initializing....");
Serial.println("Initialized Successfully");
for(int i=0;i<samples;i++)
sensors_event_t event;
accel.getEvent(&event);
xsample+=event.acceleration.x;
ysample+=event.acceleration.y;
zsample+=event.acceleration.z;
xsample/=samples;
ysample/=samples;
zsample/=samples;
Serial.println(xsample);
Serial.println(ysample);
Serial.println(zsample);
get_gps();
delay(2000);
Serial.println("System Ready..");
int xValue=xsample-event.acceleration.x;
int yValue=ysample-event.acceleration.y;
int zValue=zsample-event.acceleration.z;
Serial.print("x=");
Serial.println(xValue);
Serial.print("y=");
Serial.println(yValue);
Serial.print("z=");
Serial.println(zValue);
if(xValue < minVal || xValue > MaxVal || yValue < minVal || yValue > MaxVal || zValue < minVal || zValue > MaxVal)
get_gps();
Serial.println("Sending SMS");
Send();
Serial.println("SMS Sent");
delay(2000);
void get_gps()
// This sketch displays information every time a new sentence is correctly encoded.
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
displayInfo();
// If 5000 milliseconds pass and there are no characters coming in
// over the software serial port, show a "No GPS detected" error
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println("No GPS detected");
while(true);
void displayInfo()
if (gps.location.isValid())
Serial.print("Latitude: ");
Serial.println(gps.location.lat(), 6);
latitude=(gps.location.lat(),6);
Serial.print("Longitude: ");
Serial.println(gps.location.lng(), 6);
float longitude=(gps.location.lng(), 6);
Serial.print("Altitude: ");
Serial.println(gps.altitude.meters());
Serial.println("Location: Not Available");
void Send()
Serial1.println("AT");
serialPrint();
Serial1.println("AT+CMGF=1");
serialPrint();
Serial1.print("AT+CMGS=");
Serial1.print('"');
Serial1.print("**********8**"); //mobile no. for SMS alert
Serial1.println('"');
serialPrint();
Serial1.print("Latitude:");
Serial1.println(latitude);
serialPrint();
Serial1.print(" longitude:");
Serial1.println(logitude);
serialPrint();
Serial1.print("http://maps.google.com/maps?&z=15&mrt=yp&t=k&q=");
Serial1.print(latitude,6);
Serial1.print("+"); //28.612953, 77.231545 //28.612953,77.2293563
Serial1.print(logitude,6);
Serial1.write(26);
delay(2000);
serialPrint();
void serialPrint()
Serial.print(Serial1.read());
finalproject.ino (5.15 KB)
