Accelerometer data storage onto SD card
I am trying to store data from a BNO055 accelerometer onto an SD card. I have tried several different tests to make sure that the problem doesn't lie with the SD card, and it doesn't. When I run the code and look at the serial monitor I can see that the first set of data is stored onto the SD card but after that an initialization error appears.
Any ideas would be appreciated!
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <SD.h>
#include <SPI.h>
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055(55);
double id = .1;
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
  sensor_t sensor;
  bno.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" xxx");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" xxx");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" xxx");
  Serial.println("");
    Display some basic info about the sensor status
void displaySensorStatus(void)
  Serial.println("");
  Serial.print("System Status: 0x");
  Serial.println(system_status, HEX);
  Serial.print("Self Test:     0x");
  Serial.println(self_test_results, HEX);
  Serial.print("System Error:  0x");
  Serial.println(system_error, HEX);
  Serial.println("");
    Display sensor calibration status
void displayCalStatus(void)
  /* Get the four calibration values (0..3) */
  /* Any sensor data reporting 0 should be ignored, */
  /* 3 means 'fully calibrated" */
  uint8_t system, gyro, accel, mag;
  system = gyro = accel = mag = 0;
  bno.getCalibration(&system, &gyro, &accel, &mag);
  /* The data should be ignored until the system calibration is > 0 */
  Serial.print("\t");
  if (!system)
    Serial.print("! ");
  /* Display the individual values */
  Serial.print("Sys:");
  Serial.print(system, DEC);
  Serial.print(" G:");
  Serial.print(gyro, DEC);
  Serial.print(" A:");
  Serial.print(accel, DEC);
  Serial.print(" M:");
  Serial.print(mag, DEC);
    Arduino setup function (automatically called at startup)
void setup(void)
   pinMode(10, OUTPUT);
  Serial.println("Orientation Sensor Test"); Serial.println("");
  /* Initialise the sensor */
  if(!bno.begin())
    /* There was a problem detecting the BNO055 ... check your connections */
    Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Optional: Display current status */
  displaySensorStatus();
  bno.setExtCrystalUse(true);
    Arduino loop function, called once 'setup' is complete (your own code
    should go here)
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  bno.getEvent(&event);
  imu::Quaternion quaternion = bno.getQuat();
  /* Display the floating point data */
  Serial.print("X: ");
  Serial.print(quaternion.x());
  Serial.print(" Y: ");
  Serial.print(quaternion.y());
  Serial.print(" Z: ");
  Serial.print(quaternion.z());
  Serial.print(" Initializing SD card...");
  if (!SD.begin(4))
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  String dataString = String(id) + "," + double(quaternion.x()) + "," + double(quaternion.y()) + "," + double(quaternion.z());
  File dataFile = SD.open("Swing.txt", FILE_WRITE);
  if(dataFile)
    dataFile.println(dataString);
    dataFile.close();
    Serial.println("Could not acess file");
  /* Optional: Display calibration status */
  displayCalStatus();
  /* Optional: Display sensor status (debug only) */
  //displaySensorStatus();
  /* New line for the next sample */
  Serial.println("");
  /* Wait the specified delay before requesting nex data */
My first guess... Don't initialize the SD card on your loop, I initialize always on Setup boucle. Also be sure the select Switch is the number 4. To save data you close the file in the loop but it isn't good for datalogging. I suggest to install Sdfat library for datalogging. You could see in examples section: dataLogger sample.
Switching the initialization from the loop section to the setup section did the trick!
Thanks for your quick reply!
