Accelerometer, help
I am new with sensors such as accelerometers, therefore, I decided to check the code in the examples section. I always want to understand the code before I use it, so I read it and did not understand this part...
Memsic2125
Read the Memsic 2125 two-axis accelerometer. Converts the
pulses output by the 2125 into milli-g's (1/1000 of earth's
gravity) and prints them over the serial connection to the
computer.
The circuit:
  • X output of accelerometer to digital pin 2
  • Y output of accelerometer to digital pin 3
  • +V of accelerometer to +5V
  • GND of accelerometer to ground
created 6 Nov 2008
by David A. Mellis
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
// these constants won't change:
const int xPin = 2; // X output of the accelerometer
const int yPin = 3; // Y output of the accelerometer
// initialize serial communications:
// initialize the pins connected to the accelerometer
// as inputs:
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
// variables to read the pulse widths:
int pulseX, pulseY;
// variables to contain the resulting accelerations
int accelerationX, accelerationY;
// read pulse from x- and y-axes:
pulseX = pulseIn(xPin,HIGH);
pulseY = pulseIn(yPin,HIGH);
// convert the pulse width into acceleration
// accelerationX and accelerationY are in milli-g's:
// earth's gravity is 1000 milli-g's, or 1g.
accelerationX = ((pulseX / 10) - 500) * 8;
accelerationY = ((pulseY / 10) - 500) * 8;
// print the acceleration
Serial.print(accelerationX);
// print a tab character:
Serial.print("\t");
Serial.print(accelerationY);
delay(100);
I what unit is PulseX and Y measured in order to do the formula?
What is the logic of PulseX and Y, AccelerationX and Y?
Thank you in advance
Alrro
Look at the Memsic2125 datasheet:
Each cycle of the output is 10 mS (10,000 uS). This gives a mid-range 0 g value of 5 mS (5000 uS).
The high part of the cycle is 1250 uS per g. Multiply by 8 to get 10,000'ths of a g.
The /10 would be to convert from 10,000 per g to 1,000 per g (a.k.a. milli-g).
The -500 is to center the 0-1,000 milli-g range allowing for negative g's.
The memsic2125 is from 2008 or so. That is like the stone-age for accelerometers.
I suggest you drop your Fred Flinstone accelerometer and buy a normal one. Most newer accelerometers are cheaper and better and have 3 axis.
