Accelerometer LIS3DH multiple measurement
Hi, I am using a triple axis accelerometer LIS3DH. The sensor is placed on this breakout board.
I would like to measure four distinct sensors at the same time and my idea is the following:
  • Create a sort of clock wave, at a frequency of 1...5kHz, that goes at the same time into all of four sensors
  • At every raising edge, the four sensors (at the same time) start to measure the acceleration
  • The sensors send to my Arduino the acceleration (obviously not at the same time, but sequentially. One sensor at the time.)
This procedure is computed at quite high speed. I recall you that max sampling rate of these sensors is 5 kHz. For this reason the "clock" wave is at 1...5kHz.
How do I obtain the required procedure? Is it feasible? Regards
You will need to carefully study the device data sheet to determine if this is possible. Is there an external input to trigger a measurement?
