I'm using a 3-axis accelerometer and currently reading 2 axis only. i have used this in the past and it has worked fine. it worked fine even 30 mins back now suddenly i get a very weird error when running it and monitoring the serial port.
the code is as follows
Serial.print("X");
Serial.println(analogRead(1));
Serial.print("Y");
Serial.println(analogRead(2));
// Serial.print("Z :");
// Serial.println(analogRead(4));
The error message i get is...
java.io.IOException: No error in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:206)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Error inside Serial.serialEvent()
After getting this message i have to restart arduino or otherwise my arduino board is not recognised. what could be wrong? also off late to start the arduino Ide i have to run the run.bat file from cmd prompt and it takes a lot of time to load.
