I need the code to convert an analog voltage between 0 and 3.3 volts to a g value of -3 to 3.
Anyone able to help out?!
If 0-3.3volts represents -3g to 3g then you have 6 g's represented by 3.3v so each g is .55 volts. Since I assume 1.65v is zero g. You have g = (V / .55) - 3, but if you are reading this 0-3.3 from an Analog Arduino port that ranges from 0-1024 you can skip the voltage conversion. The 0-1024 range also represents -3 to 3 g's. So if a 512 analog reading is 0 g's then g = (Analog Reading * 6 / 1024) - 3.
To check: (0 * 6 / 1024) - 3 = -3 , (512 * 6 / 1024) - 3 = 0 , (1024 * 6 / 1024) - 3 = 3.
Is this what you were looking for?
thank you for the reply!
very helpful and easy to understand.
i'm curious..is the range 0-1024 or 0-1023?
What do you think of my code converting x axis voltage to g, for the accelerometer?
//3.3v connected to AREF
int xpin = A0;
int sv1 = 0;
int ov1 = 0;
float xg;
int led1 = 12;
analogReference(EXTERNAL);
//the analog in value:
sv1 = analogRead(xpin);
// mapping it to the range of the analog out:
ov1 = map(sv1, 0, 1023, 0, 255);
delay(2);
Serial.print("An-to-Dig-Conversion range = " );
Serial.print(sv1);
Serial.print("PMW analog output range = ");
Serial.println(ov1);
delay(3000);
//for acceleration
xg = (analogRead(0)*6 / 1024)-3;
Serial.println("MEASURING ACCELERATION... AXIS X");
Serial.println(xg);
if (xg==12 || xg==120); {
digitalWrite( led1, HIGH);
Is the if statement correctly written seeing as I want the led to turn on when the lowest or highest value of g is reached
Thank you!
float xg;
One must be very careful using equality with floats. 12.0001 is not equal to 12.0000.
These pages explain better than I can:
http://www.cygnus-software.com/papers/comparingfloats/Comparing%20floating%20point%20numbers.htm
Noting the earlier comments about testing floats for equality, but also, Oops.
Thanks guys!
Okay, aside the float, is the code okay? I'm using only the x-axis of my accelerometer. I've got the reading for g as -3, from the serial monitor.
is the code okay?
See reply #4
Please remember to use code tags when posting code
I'm only using the x-axis for now. the serial monitor reads only -3
int xpin = A0;
int sv1 = 0;
int ov1 = 0;
int led1 = 12;
delay(2);
Serial.print(sv1);
delay(3000);
//for acceleration
xg = (ov1 * 6 / 1024) - 3;
Serial.println(xg);
What do your serial prints produce?
The code cannot possibly compile, so no, it isn't correct
what do you suggest I do?
I need help regarding this and help in form of written code please. That would be easier to understand for the than explanations without code.
thanks!
Post your code.
All of it.
That is all my code!
This is what I plan to do for my project;
convert the accelerometer volts to g.
then use the highest and lowest values of g to trigger on an led.
I'm relatively new to coding so I know i'm making alot of mistakes with my code.
Please look at your reply #7.
You state
The code in that post cannot compile, so cannot print anything to the serial monitor.
So, where is the code that prints only -3?
The code that prints -3, here it is!
Serial.println(xg);
Is the mapping right?
I dont deleting everything and starting afresh if it is all wrong. I just want to get the LED turn on when the accelerometer g values are either extremes
Remember BODMAS and integer arithmetic.
(The code in reply #7 is still incomplete)
The code is compiling and uploading just fine
int xpin = A0;
int sv1 = 0;
int ov1 = 0;
float xg;
int led1 = 12;
delay(2);
Serial.print(sv1);
delay(3000);
//for acceleration
// from the calculation
//(0 * 6 / 1024) - 3 = -3 ,
//(512 * 6 / 1024) - 3 = 0 ,
//(1024 * 6 / 1024) - 3 = 3.
Serial.println(xg);
if (xg == 0 || xg == 255) {
else if (xg != 0 || xg != 255)
digitalWrite( led1, LOW);
QuinNYU:
But still has the same problem with basic arithmetic and operator precedence?
That's why I came on here for help..
How do i resolve these things?!
Floating point arithmetic?
