Accelerometro
Ciao ragazzi, stavo vedendo lo sketch di esempio per l'accelerometro adxl377, che sta sul sito della adafruit.
Questo e' il link: ADL377.
Non mi e' chiara una cosa, perche' quando usa il comando map, mette come nuovi valori -1000 e 1000?
Questo accelerometro lavora tra -200g e 200g, non dovrebbero essere questi i due estremi?
const int xInput = A0;
const int yInput = A1;
const int zInput = A2;
const int buttonPin = 2;
// Raw Ranges:
// initialize to mid-range and allow calibration to
// find the minimum and maximum for each axis
int xRawMin = 512;
int xRawMax = 512;
int yRawMin = 512;
int yRawMax = 512;
int zRawMin = 512;
int zRawMax = 512;
// Take multiple samples to reduce noise
const int sampleSize = 10;
  analogReference(EXTERNAL);
  int xRaw = ReadAxis(xInput);
  int yRaw = ReadAxis(yInput);
  int zRaw = ReadAxis(zInput);
  if (digitalRead(buttonPin) == LOW)
    AutoCalibrate(xRaw, yRaw, zRaw);
    Serial.print("Raw Ranges: X: ");
    Serial.print(xRawMin);
    Serial.print("-");
    Serial.print(xRawMax);
    Serial.print(", Y: ");
    Serial.print(yRawMin);
    Serial.print("-");
    Serial.print(yRawMax);
    Serial.print(", Z: ");
    Serial.print(zRawMin);
    Serial.print("-");
    Serial.print(zRawMax);
    Serial.print(xRaw);
    Serial.print(", ");
    Serial.print(yRaw);
    Serial.print(", ");
    Serial.print(zRaw);
    // Convert raw values to 'milli-Gs"
    long xScaled = map(xRaw, xRawMin, xRawMax, -1000, 1000);
    long yScaled = map(yRaw, yRawMin, yRawMax, -1000, 1000);
    long zScaled = map(zRaw, zRawMin, zRawMax, -1000, 1000);
    // re-scale to fractional Gs
    float xAccel = xScaled / 1000.0;
    float yAccel = yScaled / 1000.0;
    float zAccel = zScaled / 1000.0;
    Serial.print(" :: ");
    Serial.print(xAccel);
    Serial.print("G, ");
    Serial.print(yAccel);
    Serial.print(zAccel);
    Serial.println("G");
// Read "sampleSize" samples and report the average
int ReadAxis(int axisPin)
  long reading = 0;
  analogRead(axisPin);
  delay(1);
  for (int i = 0; i < sampleSize; i++)
    reading += analogRead(axisPin);
  return reading / sampleSize;
// Find the extreme raw readings from each axis
void AutoCalibrate(int xRaw, int yRaw, int zRaw)
  Serial.println("Calibrate");
  if (xRaw < xRawMin)
    xRawMin = xRaw;
  if (xRaw > xRawMax)
    xRawMax = xRaw;
  if (yRaw < yRawMin)
    yRawMin = yRaw;
  if (yRaw > yRawMax)
    yRawMax = yRaw;
  if (zRaw < zRawMin)
    zRawMin = zRaw;
  if (zRaw > zRawMax)
    zRawMax = zRaw;
Grazie,
Antonio
