Accelorometer input to LED output
In one of my engineering classes we were posed with the challenge of writing a program in which you used an accelerometer to control 3 different LED's. The premise was: "Write a program which detects when the accelerometer indicates an ecceleration > 0.5g in one axis. While the acceleration in direction (X/Y/Z) is greater thean the threshold, the corresponding LED should be on When the acceleration is less than the threshold, the LED should be off". I am completely new to Arduino and tried what I could so I understand if this is terribly written, but I'm looking for any help I can get. Thanks in advance.
// x is A0
// y is A1
// z is A2
// pin13 is X
// pin10 is y
// pin07 is z
int xPin = A0;
int yPin = A1;
int zPin = A2;
int LED1Pin = 13;
int LED2Pin = 10;
int LED3Pin = 07;
int x = 0;
int y = 0;
int z = 0;
    pinMode(xPin, INPUT);
    pinMode(yPin, INPUT);
    pinMode(zPin, INPUT);
    pinMode(LED1Pin, OUTPUT);
    pinMode(LED2Pin, OUTPUT);
    pinMode(LED3Pin, OUTPUT);
    x = analogRead(xPin);
    if (x > .5)
    { digitalWrite(LED1Pin, HIGH); }
    { digitalWrite(LED1Pin, LOW);  }
    y = analogRead(yPin);
    if (y > .5)
    { digitalWrite(LED2Pin, HIGH); }
    { digitalWrite(LED2Pin, LOW);  }
    z = analogRead(zPin);
    if (z > .5)
    { digitalWrite(LED3Pin, HIGH); }
    { digitalWrite(LED3Pin, LOW);  }
You need to specify an accelerometer device.
Hi Energroup15,
Yes, post a link to the device you are using.
The value returned by analogRead () will be a whole number (an integer) between 0 & 1023. You need to figure out what values correspond to +0.5g and -0.5g.
Paul
Thanks Paul, we figured out the correct values and it now works. Appreciate the help.
