AccelStepper: Acceleration output is constant? Should be accelerating/decelerating to control speed
Hello,
I am using the AccelStepper.h library to control a linear stepper motor in Arduino. I plotted both my acceleration and speed in terms of mm/s/s and m/s, respectively. I found an interesting result for the acceleration...it was constant. This doesn't make too much sense to me as I would have figured it would show accelerating/decelerating as the derivative of speed. Attached is my code and a figure of the output. I am printing the data to the serial plotter every 200 ms. Does anyone have an idea why acceleration is constant?
Thanks!
k
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper(AccelStepper::DRIVER, 2, 3);
#define STEPS_PER_REV 200
#define MICROSTEPS_PER_STEP 32
#define pitch 5
// Important Variable to change
int speed_desired = 4;         // mm per s
int cycles = 10;               // number of cycles to run
int distance_desired = 4;      // stroke in mm
float motor_hz_desired = 0.0;  // hz for motor
float x = 1.0;  // keeps track of cycles. Inititially at 1.
float milmets = 0.0;
float current_milmets = 0.0;
float rev_per_mm = 1.0 / pitch;
float RPMS = speed_desired * rev_per_mm * 60.0;
float hertz = speed_desired / (distance_desired * 2.0);
float steps_per_mm = rev_per_mm * (MICROSTEPS_PER_STEP)*STEPS_PER_REV;
int steps_per_mm_int = static_cast<int>(steps_per_mm);  //1280
float speed_acheived = speed_desired * steps_per_mm;  //steps per second, 5120
float milliseconds_per_cycle = ((distance_desired * 2) / speed_desired) * 1000;
int stroke = distance_desired * steps_per_mm_int;  //5120
  stepper.setMinPulseWidth(20);
  stepper.setMaxSpeed(speed_acheived);          // steps/s
  stepper.setAcceleration(speed_acheived * 2);  // steps/s/s
  stepper.enableOutputs();
  TEST_motion(stroke);
  stepper.disableOutputs();
  Serial.println("TEST COMPLETE.");
  abort();
// This function moves the motor forward and backward for a set amount of cycles. 1 cycle = foward+backward
void TEST_motion(int stroke) {
  static unsigned long lastTime;
  while (x <= cycles) {
    if (stepper.distanceToGo() == 0) {  // switches the position
      stroke = -stroke;
      stepper.moveTo(stroke);
      x = x + 0.5;
      lastTime = millis();
    stepper.run();
    if (millis() - lastTime >= 200) {
      Serial.print(stepper.currentPosition() / steps_per_mm);
      Serial.print(" ");
      Serial.print(stepper.speed() / steps_per_mm);
      Serial.print(" ");
      Serial.println(stepper.acceleration() / steps_per_mm);
Because it is programmed that way. Why should it be different? You set the acceleration in steps/sec² . Why should the Lib change that if you set it to a value of your choice?
If you set the speed to a higher value and leave the acceleration unchanged it takes longer until this speed is reached. That's very obvious to me.
I guess I would have expected the acceleration to look more along the lines of the attached image since it is accelerating/decelerating. It does make sense that it is a constant since I am setting the acceleration. I just wasn't sure if AccelStepper was changing that acceleration. Based on your comment, it is not...
