accelstepper coding not moving correctly
hi,
I am using a rain sensor (A0)analog output to drive a nema stepper,,,working but part of the code is wrong.
I have got it to home using a limit switch but then want it to stay at that home position untill A0 changes but what it does is move to -800 position then it senses A0 and moves accordingly......
In the loop section I am obviously telling "stableVal" to equal -800;;;thats why it moves there as the value of the sensor is 1023 ,no water ,,,so how would I tell it to stay at "0" then move when water changes...my logic is wrong somewhere...
would appreciate some help....please...
#include "AccelStepper.h"
// Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
// AccelStepper Setup
AccelStepper stepperX(1, 5, 4);   // 1 = Easy Driver interface
// dm320 Pin 5 connected to STEP pin of Easy Driver
// dm320 Pin 4 connected to DIR pin of Easy Driver
// Define the Pins used
#define home_switch 9 // Pin 9 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
int move_finished = 1; // Used to check if move is completed
long initial_homing = -1; // Used to Home Stepper at startup
int previous = 0;
  Serial.begin(9600);  // Start the Serial monitor with speed of 9600 Bauds
  pinMode(home_switch, INPUT_PULLUP);
  delay(5);  // Wait for EasyDriver wake up
  //  Set Max Speed and Acceleration of each Steppers at startup for homing
  stepperX.setMaxSpeed(100.0);      // Set Max Speed of Stepper (Slower to get better accuracy)
  stepperX.setAcceleration(100.0);  // Set Acceleration of Stepper
  // Start Homing procedure of Stepper Motor at startup
  Serial.print("Stepper is Homing . . . . . . . . . . . ");
  while (digitalRead(home_switch)) {  // Make the Stepper move CCW until the switch is activated
    stepperX.moveTo(initial_homing);  // Set the position to move to
    initial_homing--;  // Decrease by 1 for next move if needed
    stepperX.run();  // Start moving the stepper
    delay(5);
  stepperX.setCurrentPosition(0);  // Set the current position as zero for now
  initial_homing = 1;
  while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
    stepperX.run();
    initial_homing++;
    delay(5);
  Serial.println("Homing Completed");
  Serial.println("");
  stepperX.setMaxSpeed(1000.0);      // Set Max Speed of Stepper (Faster for regular movements)
  stepperX.setAcceleration(1000.0);  // Set Acceleration of Stepper
  // Print out Instructions on the Serial Monitor at Start
  //Serial.println("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): ");
  int sensorRead = analogRead(A0);  //read the input on analog pin 0:
  Serial.println(sensorRead);       //print out the value you read:
  delay(1000);                      // delay in between reads for stability
  int val = analogRead(A0);
  int  stableVal;
  if ((val > previous + 20 ) || (val < previous - 20 )) {
    stableVal = map (val, 0, 1023, 0 , -800);
    stepperX.runToNewPosition(stableVal);
    stableVal = previous;     // remember the previous value of the sensor
  delay(1000);  // Wait 1 seconds before moving the Stepper
I just worked it out,,,
swap stableVal = map (val, 0, 1023, 0 , -800);
to stableVal = map (val, 1023, 0, 0 , -800);
that way stable Val = 0 initially.....
int previous = 0;
  int  stableVal;
You read a value from the sensor's pin. If that value is greater than 20 or less than -20, you move the stepper. Does that really make sense?
You never assign a new value to previous, so you are NOT actually comparing the current value to a previous value.
Why does the stepper need acceleration and speed control? Exactly what is it driving?
I suspect that the regular Stepper library would be more than adequate for whatever it is you are trying to accomplish.
These links may be of interest
Stepper Motor Basics
Simple Stepper Code
...R
