Hello,
I have the following code supposed to move window roller blinds using two stepper motors. Using three states are which are Fold, unfold, and stop. which are not working properly
But the issue is when I press the fold. it moves forward successfully. then I pressed the stop in the middle of the moving forward. it actually stops
if I pressed the unfold it moves in the folding direction for a while then it unfolds then stops
can you detect where is the issue
// Include the AccelStepper library, which provides high-level features for controlling stepper motors
#include <AccelStepper.h>
// Define the pin connections for the first stepper motor
#define MOTOR1_PIN1 3
#define MOTOR1_PIN2 4
// Define the pin connections for the second stepper motor
#define MOTOR2_PIN1 5
#define MOTOR2_PIN2 6
// Define the pins for the fold, unfold, and stop buttons
#define FOLD_BUTTON_PIN 2
#define UNFOLD_BUTTON_PIN 18
#define STOP_BUTTON_PIN 19
#define FULL_COVERAGE_STEPS 1200
// Create instances of the AccelStepper class for each stepper motor.
// The first parameter (1) indicates we're using a driver, which means step and direction are controlled by two pins.
// The next two parameters are the pins for step and direction respectively.
AccelStepper stepper1(1, MOTOR1_PIN1, MOTOR1_PIN2);
AccelStepper stepper2(1, MOTOR2_PIN1, MOTOR2_PIN2);
// Define an enumeration (enum) to hold the different states that the system can be in
enum State {
IDLE_SYS, // The system is idle and waiting for a command
FOLDING, // The system is in the process of folding
UNFOLDING // The system is in the process of unfolding
// Create a variable to hold the current state of the system, and initialize it to IDLE_SYS
State currentState = IDLE_SYS;
long currentPosition1 = 0;
long currentPosition2 = 0;
// Begin serial communication at a baud rate of 9600 for debugging and interaction with the serial monitor
// Set the initial position of the stepper motor
stepper1.setCurrentPosition(0);
stepper2.setCurrentPosition(0);
// Set the maximum speed (steps per second) and acceleration (steps per second per second) for each stepper motor
stepper1.setMaxSpeed(1000.0);
stepper1.setAcceleration(500.0);
stepper2.setMaxSpeed(1000.0);
stepper2.setAcceleration(500.0);
// Set the mode of the fold, unfold, and stop button pins to INPUT so that the state of the pins can be read
pinMode(FOLD_BUTTON_PIN, INPUT);
pinMode(UNFOLD_BUTTON_PIN, INPUT);
pinMode(STOP_BUTTON_PIN, INPUT);
// Use a switch statement to do different things depending on the current state of the system
switch (currentState) {
case IDLE_SYS:
// Check if the fold button is pressed
if (digitalRead(FOLD_BUTTON_PIN) == HIGH) {
// Stop any previous movements and prepare to move the stepper motors three full rotations (600 steps)
stepper1.stop();
stepper2.stop();
// If the fold button is pressed, move the stepper motors three full rotations (600 steps) in the same direction
stepper1.moveTo(FULL_COVERAGE_STEPS - currentPosition1);
stepper2.moveTo(FULL_COVERAGE_STEPS - currentPosition2);
// Update the current state to FOLDING
currentState = FOLDING;
// Print a message to the serial monitor indicating that the folding process has started
Serial.println("Folding started...");
// Check if the unfold button is pressed
else if (digitalRead(UNFOLD_BUTTON_PIN) == HIGH) {
// Stop any previous movements and prepare to move the stepper motors three full rotations in the reverse direction (-600 steps)
stepper1.stop();
stepper2.stop();
// If the unfold button is pressed, move the stepper motors three full rotations (600 steps) in the opposite direction
stepper1.moveTo(0 - currentPosition1);
stepper2.moveTo(0 - currentPosition2);
// Update the current state to UNFOLDING
currentState = UNFOLDING;
// Print a message to the serial monitor indicating that the unfolding process has started
Serial.println("Unfolding started...");
case FOLDING:
// If the system is currently folding, run the stepper motors in the same direction
if ((stepper1.distanceToGo() != 0 && stepper2.distanceToGo() != 0) ||
(digitalRead(STOP_BUTTON_PIN) != HIGH)) {
stepper1.run();
stepper2.run();
// If the folding process is complete, update the current state to IDLE_SYS
// Print a message to the serial monitor indicating that the folding process has been completed
Serial.println("Folding completed...");
// Check if the stop button is pressed
if (digitalRead(STOP_BUTTON_PIN) == HIGH) {
currentPosition1 = stepper1.currentPosition();
currentPosition2 = stepper2.currentPosition();
// If the stop button is pressed, stop the stepper motors
stepper1.stop();
stepper2.stop();
// Update the current state to IDLE_SYS
// Print a message to the serial monitor indicating that the operation has been stopped by the user
Serial.println("Operation stopped by user...");
case UNFOLDING:
// If the system is currently unfolding, run the stepper motors in the opposite direction
( digitalRead(STOP_BUTTON_PIN) != HIGH)) {
stepper1.run();
stepper2.run();
// If the unfolding process is complete, update the current state to IDLE_SYS
// Print a message to the serial monitor indicating that the unfolding process has been completed
Serial.println("Unfolding completed...");
stepper1.stop();
stepper2.stop();
