Looking at this code, I want motor1
and motor2
to switch directions at the same time (without worrying for their position), but it doesn't work since when I change the positions of motor1
and motor2
, motor2
is still running and it will finish its movement before starting the new one.
So how can I finish that movement? I guess I could add a delay, but is there a better way to force a motor.run()
to stop for good?
*At first I was under the impression that the rotors didn't work in parallel, this was not the case and I have reedited the question entirely
#include <AccelStepper.h>
// #include <MultiStepper.h>
// 3rd gear
#define IN31 2
#define IN32 3
#define IN33 4
#define IN34 5
// 2nd gear
#define IN21 6
#define IN22 7
#define IN23 8
#define IN24 9
// 1st gear
#define IN11 A3
#define IN12 A2
#define IN13 A1
#define IN14 A0
// steps
int steps=2038; // byj28
#define FULLSTEP 4
#define HALFSTEP 8
int motor1_pos;
int motor2_pos;
int motor3_pos;
AccelStepper motor1 (HALFSTEP, IN11, IN13, IN12, IN14);
AccelStepper motor2 (HALFSTEP, IN21, IN23, IN22, IN24);
AccelStepper motor3 (HALFSTEP, IN31, IN33, IN32, IN34);
bool running = true;
bool first_time = true;
Serial.println("GO");
pinMode(IN11, OUTPUT);
pinMode(IN12, OUTPUT);
pinMode(IN13, OUTPUT);
pinMode(IN14, OUTPUT);
pinMode(IN21, OUTPUT);
pinMode(IN22, OUTPUT);
pinMode(IN23, OUTPUT);
pinMode(IN24, OUTPUT);
pinMode(IN31, OUTPUT);
pinMode(IN32, OUTPUT);
pinMode(IN33, OUTPUT);
pinMode(IN34, OUTPUT);
// slow movement
motor3_pos = -100;
motor3.setMaxSpeed(1000);
motor3.setAcceleration(200);
// motor3.setSpeed(25);
motor3.moveTo(motor3_pos);
// coordinated and fast movement
motor1_pos = 200;
motor1.setMaxSpeed(10000);
motor1.setAcceleration(1000);
// motor1.setSpeed(1000);
motor1.moveTo(motor1_pos);
motor2_pos = -200;
motor2.setMaxSpeed(10000);
motor2.setAcceleration(10000);
// motor2.setSpeed(1000);
motor2.moveTo(motor2_pos);
rotate();
int rotations = 0;
void rotate()
motor3.run();
if (rotations == 20)
Serial.println("rotations is 20");
running = false;
// change of direction
if (motor3.distanceToGo() == 0) {
Serial.println("change of direction");
if (motor3.currentPosition() != 0)
motor3.moveTo(0);
rotations++;
first_time = false;
// if a cycle has completed, call pullout()
if (!first_time && rotations % 2 == 0) {
Serial.println("cycle completed");
pullout(); // rotate() will be called by pullout() once it finishes
if (running)
rotate();
if (running)
rotate();
int pullouts = 0;
void pullout()
motor1.run();
motor2.run();
if (motor1.distanceToGo() == 0) {
pullouts++;
if (motor1.currentPosition() != 0) {
motor1.moveTo(0);
motor2.moveTo(0);
if (pullouts == 4) {
pullouts = 0;
rotate();
} else
pullout();
} else
pullout();
// delay(2000);
