I am using the AccelStepper library with an Uno, a 28BYJ-48 stepper motor and the driver card that came with it. My problem is that using the stepper.moveTo, stepper.setSpeed, stepper.run functions give inconsistent motor speed but using the stepper.runToNewPosition gives consistent results.
If I go to position 1026 and then go to position 0, using runToNewPosition the motor runs at the same speed in both directions. However if I use the moveTo, setSpeed, run combination of functions the motor runs at the expected speed going to position 1026 but going back to 0 it moves very slowly for the first 200 steps or so and then completes the rest of the move at expected speed. My code is attached.
The purpose of this code (it is test code for a larger function) is to read a heading in decimal degrees and move a pointer on the stepper motor to the degree position on a compass rose. I want to use the function combination so I do not have any blocking code in my main loop.
Can you please shed some light on what I may have done wrong?
Dale Gloer
This test is for one decimal place inputs and sends fractional steps to the
stepper motor operating in half step mode. Input is nnn.n
#include <AccelStepper.h>
#define HALFSTEP 8
// Motor pin definitions
#define motorPin1 3 // IN1 on the ULN2003 driver 1
#define motorPin2 4 // IN2 on the ULN2003 driver 1
#define motorPin3 5 // IN3 on the ULN2003 driver 1
#define motorPin4 6 // IN4 on the ULN2003 driver 1
// Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
String heading;
int headingi;
int steps;
int stepsOld(000);
float stepsf, headingf, stepsfOld(0.0);
stepper1.setMaxSpeed(1000.0);
stepper1.setAcceleration(100.0);
stepper1.setSpeed(200);
Serial.begin(115200); // turn on Serial Port
Serial.println("Enter heading in decimal degrees, eg 123.5 ");
} //--(end setup )---
if(Serial.available() != 0) {
// Read serial input:
heading = "";
heading += getChar();
headingf = heading.toFloat();
Serial.print("heading: ");
Serial.println(heading);
Serial.print(" headingf ");
Serial.println(headingf);
stepsf=headingf*11.4;
Serial.print(" stepsf ");
Serial.println(stepsf);
if(stepsf!=stepsfOld) {
// call a functiion to move the stepper
RunStepper(stepsf);
Serial.println(" did it ");
stepsfOld=stepsf;
// Serial.println(" In main loop ");
stepper1.run();
char getChar() // Function to get a character from the serial buffer
Serial.println(" in getChar");
while(Serial.available() == 0); // wait for data
return((char)Serial.read()); // Thanks Doug
void RunStepper(float s) // Function to move the stepper motor
// stepper1.runToNewPosition(s);
stepper1.moveTo(s);
