I'm using an Arduino uno and I have a limitswitch for homing. I will send here the complete sketch. I have many variables that are labeled in german. They are basically to calculate the needed steps for a certain thickness of wire. I'm also using an LCD and 5 buttons to enter all the needed parameters. The LCD menu with the buttons is based on this youtube video: Ep. 59 - Arduino LCD Display Menu System Tutorial, Scrolling Menu, Changeable Variables for Projects - YouTube
Also I made it so that if some parameters are 1 as an example the parameter [4] than the void autohome gets activated and so on. The code is probably quite confusing because I'm not really into coding but I hope someone can figure it out. Everything works except the mentioned thing with the slider motor movement getting randomly interrupted sometimes. Thanks in advance!
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#include <AccelStepper.h>
float count = 0;
float rotations = 0;
float slidersteps;
float Durchmesser = 0.10;
float Wicklungen;
float rotationsteps = 0;
float Lange;
float rotationsold = 0;
float Start;
float OnlyRotate;
float CoilDiameter;
float WireLength;
int Endswitch;
int Multiplier;
boolean didMyOneTimeAction = false;
AccelStepper stepper1(AccelStepper::DRIVER, 2, 3);
AccelStepper stepper2(AccelStepper::DRIVER, 4, 5);
//Input & Button Logic
const int numOfInputs = 4;
const int inputPins[numOfInputs] = {6,9,8,7};
int inputState[numOfInputs];
int lastInputState[numOfInputs] = {LOW,LOW,LOW,LOW};
bool inputFlags[numOfInputs] = {LOW,LOW,LOW,LOW};
long lastDebounceTime[numOfInputs] = {0,0,0,0};
long debounceDelay = 5;
//LCD Menu Logic
const int numOfScreens = 9;
int currentScreen = 0;
String screens[numOfScreens][2] = {{"Turns",""}, {"Wire Diameter", "mm"},
{"Coil Length","cm"},{"Start Winding",""}, {"Auto Home", ""}, {"Only Rotate",""}, {"Move Sled",""}, {"Coil Diameter","cm"}, {"need Wire Length","m"}};
float parameters[numOfScreens];
for(int i = 0; i < numOfInputs; i++) {
pinMode(inputPins[i], INPUT);
digitalWrite(inputPins[i], HIGH); // pull-up 20k
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
//Serial.begin(9600);
lcd.init();
lcd.backlight();
setInputFlags();
resolveInputFlags();
Wicklungen = parameters [0];
Durchmesser = parameters [1];
Start = parameters [3];
OnlyRotate = parameters [5];
slidersteps = Durchmesser * 100;
rotationsteps = Wicklungen * 200;
Lange = (Wicklungen * Durchmesser)/10;
parameters [2] = Lange;
CoilDiameter = parameters [7];
WireLength = ((CoilDiameter *3.14) * Wicklungen)/100;
parameters [8] = WireLength;
stepper1.setMaxSpeed(200.0);
stepper1.setAcceleration(30.0);
stepper2.setMaxSpeed(500);
stepper2.setAcceleration(500);
if(Start == 1){
WindCoil();
if(Start == 0){
stepper1.stop();
stepper2.stop();
stepper1.setCurrentPosition(0);
if(OnlyRotate == 1){
Rotate();
if(parameters [6] == 1){
MoveSled(1);
if(parameters [6] == -1){
MoveSled(-1);
if(parameters [4] == 1){
AutoHome();
void WindCoil(){
if (didMyOneTimeAction == false){
didMyOneTimeAction = true;
stepper1.moveTo(-rotationsteps);
rotations = stepper1.currentPosition()/200;
if(rotations != rotationsold){
rotationsold = rotations;
stepper2.move(100); //slidersteps
stepper2.run();
stepper1.run();
if (stepper1.distanceToGo() == 0){
delay(200);
parameters [3] = 0;
void Rotate(){
stepper1.setMaxSpeed(40.0);
stepper1.setSpeed(-30);
stepper1.run();
void MoveSled(int Direction){
if (Direction == 1){
stepper2.setMaxSpeed(200);
stepper2.setSpeed(100);
stepper2.run();
if (Direction == -1){
stepper2.setSpeed(-100);
stepper2.run();
void AutoHome(){
stepper2.setMaxSpeed(800);
stepper2.setSpeed(-800);
stepper2.run();
Endswitch = digitalRead(10);
if(Endswitch == 0){
parameters [4] = 0;
void setInputFlags() {
int reading = digitalRead(inputPins[i]);
if (reading != lastInputState[i]) {
lastDebounceTime[i] = millis();
if ((millis() - lastDebounceTime[i]) > debounceDelay) {
if (reading != inputState[i]) {
inputState[i] = reading;
if (inputState[i] == HIGH) {
inputFlags[i] = HIGH;
lastInputState[i] = reading;
void resolveInputFlags() {
if(inputFlags[i] == HIGH) {
inputAction(i);
inputFlags[i] = LOW;
printScreen();
void inputAction(int input) {
if(input == 0) {
if (currentScreen == 0) {
currentScreen = numOfScreens-1;
}else{
currentScreen--;
}else if(input == 1) {
if (currentScreen == numOfScreens-1) {
currentScreen = 0;
}else{
currentScreen++;
//Parameter Plus/Minus durch Drücken des Knopfes
else if(input == 2) {
if(currentScreen == 1){
parameterChange(2);
if(currentScreen == 0){
Multiplier = digitalRead(11);
if(Multiplier == 0){
parameterChange(6);
else{
parameterChange(4);
if(currentScreen == 2){
parameterChange(0);
if(currentScreen == 3){
parameterChange(0);
if(currentScreen == 4){
parameterChange(0);
if(currentScreen == 5){
parameterChange(0);
if(currentScreen == 6){
parameterChange(0);
if(currentScreen == 7){
parameterChange(0);
if(currentScreen == 8){
parameterChange(0);
else if(input == 3) {
parameterChange(3);
parameterChange(7);
else{
parameterChange(5);
parameterChange(1);
parameterChange(1);
parameterChange(1);
parameterChange(1);
parameterChange(1);
parameterChange(1);
parameterChange(1);
void parameterChange(int key) {
if(key == 0) {
parameters[currentScreen]++;
}else if(key == 1) {
parameters[currentScreen]--;
}else if(key == 2){
parameters[currentScreen] = parameters[currentScreen] + 0.01;
}else if(key == 3){
parameters[currentScreen] = parameters[currentScreen] - 0.01;
}else if(key == 4){
parameters[currentScreen] = parameters[currentScreen] + 10;
}else if(key == 5){
parameters[currentScreen] = parameters[currentScreen] - 10;
}else if(key == 6){
parameters[currentScreen] = parameters[currentScreen] + 100;
else if(key == 7){
parameters[currentScreen] = parameters[currentScreen] - 100;
void printScreen() {
lcd.clear();
lcd.print(screens[currentScreen][0]);
lcd.setCursor(0,1);
lcd.print(parameters[currentScreen]);
lcd.print(" ");
lcd.print(screens[currentScreen][1]);
