Accelstepper multiple movement commands
I am using Accelstepper lib to drive 2 stepper motors, I couldn't find an example of using multiple movement commands, so I tried myself.
This is what I came up with, and it is working perfectly, however I feel there must be an easier way to manage doing this! If anyone has some ways I could improve this it would be great.
I need to move to a few different positions so I am using a switch statement to cycle through the moveTo(); commands then breaking out to run the stepper.run(); to actually move the stepper. This needs to be run very fast.
Ideally I would like to put this into a function to be called in the main loop, but so far I could not get that to work.
Any comments on how I could improve would be greatly appreciated. Thanks!
if (runProduction == true) {
  if (clampStepper.distanceToGo() == 0) // Make sure there is not a move happening
    switch (clampMotorStatus) // cycles through each command to change the position
      case 1:
      clampStepper.setMaxSpeed(5000);
      clampStepper.setAcceleration(5000);
      clampStepper.moveTo(stepsPerMMClamp*50);
      clampMotorStatus ++;
    case 2:
      //clampStepper.setMaxSpeed(1000);
      //clampStepper.setAcceleration(1000);
      clampStepper.moveTo(stepsPerMMClamp*30);
    case 3:
      clampStepper.moveTo(stepsPerMMClamp*40);
    case 4:
      clampStepper.moveTo(stepsPerMMClamp*0);
      clampMotorStatus = 1;
  clampStepper.run();  // Start moving the stepper
jackdavies:
Your code only moves one motor but you said there are two.
Why does it need to run very fast? And what needs to run fast - the motor, or the changes of position?
Your code does not test for whether the motor has reached the position.
If you want to put that piece of code in a function you just need to precede it with
void myFunction() {
and follow it with a closing }. Then, in loop() call it with myFunction();
(I assume you will choose a more meaningful name for the function)
Maybe have a look at Planning and Implementing a Program
...R
Hi Robin,
Thanks for your reply, I should have been more clear. The loop of calling the stepper.run(); needs to be very fast to keep generating pulses for the motor as I understand, so that needs to be constantly running. However I need to move a motor to a position and then change to another specific position. All while the loop is running to actually move the motor.
I know the syntax of writing a function, but basically I wanted to just call a function to do the motor commands, but with the needed loop of stepper.run(); I just got that to work by also moving stepper.run();inside the function.
Really my main question was is that a good method of updating the motor position using the switch case statement? Or is there a more elegant way that I am missing?
Cheers, Jack
jackdavies:
It would be more usual to have stepper.run() (for all the motors) in loop() so it gets called all the time.
Your SWITCH/CASE system seems fine.
...R
