AccelStepper smooth faster/slower speed while running
Hello,
I managed to modify the speed every ~x sec while running with this code :
#include <AccelStepper.h>
#define MotorInterfaceType 4
AccelStepper stepper = AccelStepper(MotorInterfaceType, 0, 2, 1, 3);
unsigned long previousMillis = 0;
int interval = 1200;
  stepper.setAcceleration(50);
  if
  (currentMillis - previousMillis >= interval) {
  stepper.setMaxSpeed(random(100,860));
  stepper.move(6000);
  interval = random(2000,5050);
  stepper.run();
But It is not fluid as I would like it to be.
If it does have to go faster, the acceleration is working. But if it does have to slow, It slows down roughly.
Any idea how I could get the speed smoothly slow down ?
how can you tell if you are randomly setting the speed and the time between changes in speed?
I think this is because max speed is not supposed to change while a motor is moving.
Maybe use setSpeed() to change speed, and runSpeed() rather than run()
Didnt work out, maybe someone could help me with a fading system or something ? smooth increment instead of changing the speed directly
It is not very difficult to write your own acceleration code without needing the library. Simple acceleration code.
...R
